November 26, 2025, 03:50:27 AM *
Author Topic: rear tire  (Read 822 times)
wat
« on: July 29, 2014, 08:31:19 PM »
I have 2000 interstate 1500 with 205/60R16 rubs right side replaced bearings no help any ideas. ok rest of story, car tire Fuzion HRi was on bike when I got it. it says 1 ply side wall. I also have a side car on bike. ribs drive shaft housing. bearings were replaced by  dealer. the bike has 92,000 miles.
« Last Edit: July 30, 2014, 10:28:40 AM by wat » Logged
« Reply #1 on: July 29, 2014, 08:42:44 PM »
Where is it rubbing? On the shaft housing, nut cage, inside top of fender ?
« Reply #2 on: July 29, 2014, 09:01:18 PM »
If ya have pictures of the tire and where it is rubbing would be real helpful for us.
Also, what brand of tire, and is it a MC or CT?
Give us as much information as possible.
« Reply #3 on: July 29, 2014, 09:01:35 PM »
I run a 205-65-16 and no rub. Did you follow sequence when putting tire back in swing arm?? Plus the questions meathead asked. RIDE SAFE.
saddlesore
« Reply #4 on: July 29, 2014, 09:29:01 PM »
I run the same size tire. I did the nut cage modification but for some stupid reason the bolt I used was too long. When I would hit a big enough bump the outside ridge of the tire would rub.
DARE TO BE DIFFERENT
Kunkies
Charlotte, NC
« Reply #5 on: July 30, 2014, 10:44:06 AM »
Stock or after market rear shocks?  If the latter, what length are the shocks?
