February 09, 2026, 08:26:14 AM *
Author Topic: Dark Side  (Read 1024 times)
Louis Durocher
'99 Interstate
Montreal,Canada
« on: August 02, 2014, 03:49:52 PM »
What is the advantage to go to the dark side? Any advice?
Have a safe ride
« Reply #1 on: August 02, 2014, 03:56:13 PM »
If you will use the search function on the general and the tech board you WILL find more than you MIGHT wanna know bout the D/S. There is a LOT of information out there on your subject.  cooldude Happy reading.  coolsmiley RIDE SAFE.
« Reply #2 on: August 02, 2014, 04:59:23 PM »
For me the advantage is tire mileage and tire cost.
« Reply #3 on: August 02, 2014, 05:42:49 PM »
Some of the advantages and disadvantages are increased or decreased depending upon which tire you choose.
Advantage - Handling in the rain or on wet surface.
Advantage - Rear wheel and overall braking.
Advantage - Stability coming to a stop.
Disadvantage - Low speed handling on uneven surfaces.
Advantage - Tire cost.
I may have left something out.
« Reply #4 on: August 02, 2014, 05:53:01 PM »
flaming death ?
« Reply #5 on: August 02, 2014, 05:58:13 PM »
Disadvantage - Constant pressure required on the inside handgrip in a corner.  The bike will straighten out otherwise.
Disadvantage - When trying to plug a puncture on the road, the steel belts make it real tough to ream out the hole so the plug will go in.
Disadvantage - Might be tough to find a shop to mount the tire for you.
Advantage/Disadvantage - Conversation piece.
Paxton
So Cal
« Reply #6 on: August 02, 2014, 07:14:43 PM »
Looks awesome! cooldude
J. Paxton Gomez
1978 Honda 750F / Cafe Racer
So Cal... 91205
« Reply #7 on: August 02, 2014, 07:26:20 PM »
Advantage..... much harder to get a puncture wound all the way thru, and a safer tire if it does get punctured.
Wewaman
Dead Lakes Cruiser
Wewa, Fla.
« Reply #8 on: August 02, 2014, 08:43:03 PM »
Advantage / add Ride On and it seals punctures, it also balances your tire.
Read Daniel Meyers write up in shop talk.
« Last Edit: August 02, 2014, 08:45:00 PM by Wewaman » Logged
If you please God it doesn't matter who you displease   but if you displease God it doesn't matter who you please Smiley
Andy Cote
Windham, Maine
« Reply #9 on: August 03, 2014, 04:28:53 AM »
Bonjour.
Darkside is not for everyone.  Just like traditional tires, different brands have different feel.  Try one first if you can.  As mentioned above, there are some other posts and info on the tech pages.
I have darkside tires on both the Wing and the Valk.  I didn't really find any difference in handling, even low speed.  The Wing has about 16000 on an Austone and it still looks fine.  I only have about 2000 on the Valk with the Falken so while it feels fine, not sure on wear quite yet.
If you are headed to the ME or NH, shoot me an e-mail and I may be able to meet you.
You may also want to read these sites:
http://valkyrie-owners.com/SMFORUM/index.php?PHPSESSID=167e55d54feff008e32ee51fbf86d934&board=27.0
http://mcdarksiders.forumotion.com/
2015 Goldwing, basic black
Previously: 2000 Valkyrie Interstate, 1997 Valkyrie Standard, 1988 GL1500, GL1200 Standard, GL1200 Interstate and many other Hondas
doniholcomb
« Reply #10 on: August 03, 2014, 09:50:51 AM »
the most important advantage is that really looks badass going down the road especially whenever you're getting your picture takenI have been dark side for about  3 years now and would have replaced a motorcycle tire at least once by now however my dark side tire you can't even tell that is being use better handling on the curves but I have noticed that is a little bit harder to control at low speeds and whenever you get into a rut it has a tendency to follow the rutt.  I just wish that they still made the cool patches
DarkSideR
Pueblo, Colorado
« Reply #11 on: August 04, 2014, 09:37:38 AM »
I would suggest considering the following.
You may want to stay with a Motorcycle tire if;
 - you ride less than 6 thousand miles a year.
   +average life of a M/C tire is about 6k thus 1 new tire a year.
 - you don't like to spend $200+ on one tire.
You may want to Darkside if;
 - you ride more than 6k a year.
   +average life of a D/S tire is about 16k (have seen reports over 20K).
 - you want to spend less on a tire
   +you can spend anywhere from $60-$170 and get great D/S tires.
 - you tow a trailer.
   + delamination of M/C tires have been reported when towing trailers.
I ride a lot. Replacing an expensive M/C tire 2-3 times a year was out of the question. I first rode a Good Year Triple Tread, and though I got 17k out of it I didn't like it's handling. I now ride a Vredestein Sportrac 3. Phenomenal handling tire, but you can't buy them anymore. You can't go wrong with the Austone Taxi Tire (you can only get them here https://www.universaltire.com/175r16-austone-taxi-black.html).
My Ups ++++
 + Life of the tire  cooldude
 + Safely plugging a puncture  cooldude
 + My wife prefers the ride on the back seat with the D/S tire  cooldude
 + Wet and gravel rode traction is excellent  cooldude
 + Rear braking is hugely improved  cooldude
My downs ----
 - have gotten harassed on the road  tickedoff
 - have gotten harassed here on the VRCC  tickedoff
 - finding a tire shop to mount the tire   Undecided
Hope this helps you make an informed decision. Let us know what you end up doing.
« Last Edit: August 04, 2014, 11:30:01 AM by Joshcornkid » Logged
2001 Valkyrie Super Tourer
VRCC#34410
VRCCDS#0263
