November 26, 2025, 03:46:10 AM *
Author Topic: How do I get power to a Woody's fairing?  (Read 692 times)
Safety Steve
« on: August 02, 2014, 04:17:22 PM »
I just bought a Woody's fairing and I was wondering how do I get power to the fairing to power up my radio?
Any info would be great.
Thank you
Steve
« Reply #1 on: August 02, 2014, 05:39:05 PM »
Not sure what you're asking exactly.
Your stereo should have some wiring instuctions.
You can buy a fuse block of some sort and power everything off of that.
I bought a PC-8 fused terminal block from Eastern Beaver.  It's the only thing wired from the battery.  Mounted it in the area behind the battery where the oem tool pouch goes.
I powered everything I have on the bike off of the PC-8 up to the Woodys.
doniholcomb
« Reply #2 on: August 03, 2014, 10:02:59 AM »
Call glenn
« Reply #3 on: August 03, 2014, 05:33:30 PM »
+1 PC-8
http://www.easternbeaver.com/Main/Wiring_Kits/Fuseboxes/PC-8/pc-8.html#50akit
Simple to do cooldude
etiwandablues
Kennewick, WA
« Reply #4 on: August 06, 2014, 12:20:22 PM »
Another option is the Fuzeblock FZ-1. It may not have enough capacity for some applications but has some nice features ... compact, 6 circuits, 10a max per circuit, 30a total, 30a relay and ea circuit can be set up as either switched or constant power. I used one of these when I installed a Woody's fairing this year. I mounted it in a weatherproof plastic box that easily fit under the right side cover. Zero miles on it so far so hopefully it works as well as advertised.
