November 26, 2025, 03:50:23 AM *
Author Topic: Progressive 416 air - oil chambers  (Read 1338 times)
quexpress
Montreal, Québec, Canada
« on: August 04, 2014, 09:09:24 AM »
Hi!
Progressive mention in their instructions to add oil through the bottom while changing the seals.
However 416 shocks leak through the air valve if you tip them upside down. This tells me that the air - oil chambers might not be completely separate.
My "new to me" slightly used 416s leaked a little bit during shipping. I'm tempted to add 1 once of ATF through the air valve but am wondering if this would/could have any negative effects.
Any insight by those who have rebuilt these would be much appreciated.  Smiley
I still have a full deck.
I just shuffle slower ...
« Reply #1 on: August 05, 2014, 08:06:48 AM »
I don't think it's leaking through the piston or valves, but oil in upper and lower chambers.
I have their instructions saved off on my office computer but I'm on a road trip, probably not with me.  They are confusing and contradictory, talk about putting oil in the top and the bottom.  In the top won't hurt, but it will come out into the air line.  They say in one place the max amnt of ATF fluid is 2oz and in another, 6.  They also say don't add extra oil but their rep that used to hang out here advised me to do that, to increase the compression rate and load capacity.  That does work.
Here's a link from last year I posted on it.  I thought there was one this year too but I'm not guessing the right search terms apparently.  I'm thinking you can find their service and owner's manuals on their web site.
http://www.valkyrieforum.com/bbs/index.php/topic,53600.msg514018.html#msg514018
quexpress
« Reply #2 on: August 05, 2014, 03:13:21 PM »
Hi Mark!
I had already read your posts about the 416s and also downloaded your 3 PDF documents. These have been VERY helpful!
I'm not in a hurry to open these up since they don't leak. However I guess the light will come on when I have one of these opened up to change the oil seals.
Thanks a lot! Your reply, PDFs and informative posts have been very appreciated!  cooldude
Normand
