January 29, 2026, 08:30:02 AM
oil temp light flickering!
Topic: oil temp light flickering! (Read 1861 times)
Fajack
August 09, 2009, 03:40:00 PM »
oil temp light is flickering cked oil and coolant which are OK. Is best to go to a mechanic to ck fan, thermostat etc or is there something easy I can fool with
Thanks in advance
Jack
Re: oil temp light flickering!
August 09, 2009, 03:44:26 PM »
Lots of the temp sensors go bad and send false readings. BTW: It's a water temp sensor. Chances are there's nothing wrong with your cooling system. You just need a new sensor.
August 09, 2009, 04:40:37 PM »
Quote from: sandy on August 09, 2009, 03:44:26 PM
10-04 what sandy says.
Does your fan come on & off frequently?
If so, it might be time for a coolant replacement also.
vanagon40
Greenwood, IN
August 09, 2009, 08:41:00 PM »
Is this a Standard/Tourer or an Interstate? Is it the oil pressure light or the coolant temperature light? The responses above seem to "assume" the light was the temperature light based upon your questions, but did you mean the temperature light or the oil pressure light?
Fajack
August 10, 2009, 04:50:47 AM »
It was the light all the way on the left...I guess it was the temp light not the oil light which is in the middle
