February 27, 2026, 03:29:53 PM *
Author Topic: removing the forks  (Read 1491 times)
CB1
DFW, TX
« on: August 08, 2014, 08:01:57 AM »
hi all,
I am about to remove my 1998 Valk Tourer forks to change out leaky seals. I have all of the tools to remove the forks but I see that I don't have a socket/wrench large enough for the fork cap.
what size wrench/socket would this be? the Honda service manual does not list sizes, just tool part numbers.
Thanks!
pic of valk...  cooldude
Thanks!
Chris
« Reply #1 on: August 08, 2014, 09:33:10 AM »
Do what I would do if my bike were close by: put a tape measure or ruler on it.  By the way, once you get your cap off, there is a nut under the cap of one of the forks that requires a unusually slender wrench to loosen.  The OEM toolkit contains such a wrench.
« Last Edit: August 08, 2014, 09:35:49 AM by Gryphon Rider » Logged
« Reply #2 on: August 08, 2014, 10:19:11 AM »
make sure you loosen those cap nut covers before removing the fork tubes.  Much easier that way
« Reply #3 on: August 08, 2014, 10:24:24 AM »
I believe a 15/16th socket will work just great.  cooldude
My rides:
CB1
DFW, TX
« Reply #4 on: August 08, 2014, 12:14:33 PM »
thanks guys!
Thanks!
Chris
bentwrench
Philadelphia,Pa.
« Reply #5 on: August 08, 2014, 02:33:43 PM »
I use a good 22mm6pt.with sheet of plastic from a heavy trash bag so it mar the cap.
« Reply #6 on: August 08, 2014, 07:41:15 PM »
Loosen the top pinch bolts, loosen the cap before loosening the lower pinch bolts. I use a 15/16 " box end wrench.
Dusty
Mill Bay B.C.
« Reply #7 on: August 08, 2014, 10:35:10 PM »
Make sure your bike is well supported before pulling the fork tubes. On my Interstate when I undid the tubes and removed them the bike wanted to tip backwards off the bike lift. Be aware.
Dusty
CB1
DFW, TX
« Reply #8 on: August 17, 2014, 05:55:24 PM »
Got 'er done!
not counting the time the forks were at the dealer for the actual work, (I don't have the time or special tools to do it) it took a total of 45 minutes to remove and install the tubes. The tubes were rebuilt with new seals and bushings.
for the record, the tools needed are
4mm,5mm,6mm,8mm allen head sockets
8mm,12mm, 22mm(axle) and 24mm(fork caps) sockets
pics of forkless Valkyrie
The rebuilt tubes
ready to ride!
Thanks!
Chris
« Reply #9 on: August 18, 2014, 04:45:08 AM »
Congrats!  cooldude  Did find anything challenging? ???
My rides:
olddog1946
Moses Lake, Wa
« Reply #10 on: August 18, 2014, 08:14:02 PM »
Those forks look pretty stinkin good. Nice and clean, still got the clear coat in good shape.
Don't know what you paid to have those forks seals and bushings done but you'd only add a half hour to the job if you do your own. Though I would recommend the actual seal installation tool as opposed to the pvc. I did my neighbors on the bike, and was amazed at how easy it was. There is a post in the tech section on doing it..easy peazy...hardest part was measuring the oil to put back in.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
