February 09, 2026, 08:57:33 AM *
Author Topic: Fork seal change imminent  (Read 1137 times)
« on: August 08, 2014, 09:30:44 AM »
Looks like the ol' right fork seal has finally had enough.  It held on for quite a while after a SealMate treatment last summer, but it doesn't look like that will work this time.    Sad
I just ordered an All Balls seal kit.  Just curious, what would be a fair price (or reasonable time charge) for a shop to install them?
« Last Edit: August 08, 2014, 10:38:47 AM by Valkorado » Logged
« Reply #1 on: August 08, 2014, 01:37:15 PM »
the right fork started to link again, found this site
http://www.rswracing.com/airout.htm  and doing some searching it seams inverted forks can build up pressure inside thereby forcing out fluid.
I roll the bike backwards while sitting on it and then apply the brakes while pulling back on the handle bars causing the forks to extend. did a few times. the leak is now almost non-existent. I have also noticed more leakage from different temp changes.
something to try.
« Reply #2 on: August 08, 2014, 08:24:47 PM »
Thanks CA, that's pretty much how I fixed them the first time, SealMate and bouncing the hell out of 'em.  It's really shot this time.  I was just wondering what I should expect to be billed for the install, hopefully not more than an hour.
0leman
Klamath Falls, Or
« Reply #3 on: August 09, 2014, 09:31:35 AM »
Local shop charged me around $100 to put in new seals.   I got the seals, pulled the forks off, and took them in.   The shop cleaned up the outside/inside of forks, put in the new seals, and warn me that would need bushing next time.   Figured it was well worth the money.
Earl in Pensacola
« Reply #4 on: August 09, 2014, 03:51:45 PM »
A friend here in Pensacola took his '98 standard to a respected shop and it cost him about $375.00 parts and labor.  Parts = All new OEM bushings,sliders? and seals etc.
twdurdentwd
Sebastian, Florida
« Reply #5 on: August 12, 2014, 10:26:16 AM »
How much are the parts?
00' Valk tourer - 6-6, trigger wheel
00' Valk std - complete build
00' I/S salvaged.. Transplant to std
olddog1946
Moses Lake, Wa
« Reply #6 on: August 13, 2014, 07:22:12 AM »
I seem to remember the parts were about $105 for bushings and seals. I paid $90 bucks to have mine done the first time, but once I found out how easy it was to change things out on my neighbors bike I won't be paying that money again.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
« Reply #7 on: August 13, 2014, 07:31:51 AM »
Actually the fork seal/dust cover kits can be found for around $20.  It's the $85/hr. mechanic charge that hurts.  $90 installation charge sounds like they billed out an hour's labor.
« Reply #8 on: August 13, 2014, 07:38:19 AM »
The manual lists several bushings as wear parts too... When I took my forks apart it was apparent there was wear on
some of the bushings...
Troystg
DC
« Reply #9 on: August 13, 2014, 10:05:22 AM »
The local Honda dealer here quoted ~$300 for the pair and ~$400 if they needed to change out the front brake pads because of the oil.
Fortunately the sealmates fixed my leak for now.
Troy
Troy
