January 29, 2026, 08:30:30 AM *
Author Topic: U-Joint  (Read 1760 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: August 10, 2009, 05:51:30 AM »
Is there a section on U-Joint and driveshaft removal that I missed in Shop-Talk?  Do I need to remove the swing arm to get at the U-Joint?
Joe Hummer
Arnold, MO
« Reply #1 on: August 10, 2009, 06:00:54 AM »
You do not have to remove the swing arm to change out the driveshaft.
You will have to do the following:
1)  Remove the rear tire and shocks.
2)  Remove the final drive unit by removing the 4 nuts.
3)  Slide the drive unit out.  The drive shaft will come out with the drive unit.
4)  Remove the rear brake reservoir and bracket to gain access to the U-Joint boot.
5)  Pop the boot off the motor and swing-arm and remove from the bike.
6)  With the swing arm in the down position, thread the U-Joint out.
Installing the new U-Joint is the reverse.  One gotcha though, lube the boot with a little grease, WD-40, or similar slippery substance to aid putting it back on.
Another gotcha, don't tighten the drive unit bolts until after you put the tire back on and tightened (not necessarily torqued).  This will help align the drive unit with the wheel so you don't put the rear end in a bind.
Hope this helps.
Joe
P.S.  Found this after I typed all this in...  http://www.rattlebars.com/mtz/ujoint.html  Note:  If you remove the shocks, you do not need to remove the exhausts.  You can lift the wheel up to slide the axle out.
« Last Edit: August 10, 2009, 06:02:40 AM by JoeValkIS » Logged
1999 Valkyrie Interstate
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #2 on: August 10, 2009, 06:06:52 AM »
Of course this helps, exactly what I was looking for!!! Thanks Joe for the quick response and link cooldude
« Last Edit: August 10, 2009, 09:01:35 AM by Tundra » Logged
« Reply #3 on: August 10, 2009, 09:36:50 AM »
He just replaced his U joint at Inzane.
« Reply #4 on: August 10, 2009, 09:53:51 AM »
Give a firm pull on the drive shaft and it will pull out of the final drive.
