September 09, 2025, 03:22:15 PM
IS POD lights
Topic: IS POD lights (Read 834 times)
mrider
IS POD lights
August 12, 2014, 05:33:56 PM »
I have a 99 IS with the pod lights the problem is i believe my switch is bad.......power going in nothing coming out. I bought this bike and had to take a lot of crap wireing off have i missed something? is there a switch out there? can i use a different switch? thanks for the help.
Re: IS POD lights
August 12, 2014, 05:58:36 PM »
The original install manual is here,
http://valkyrienorway.com/download.html
Down load it and see if it answers your questions.
You should be able to us any type of proper switch you want.
Re: IS POD lights
August 12, 2014, 08:45:43 PM »
Original switch is available from Electrical Connections or J&M.
Re: IS POD lights
August 13, 2014, 02:42:10 PM »
There is a relay for those lights too. Make sure you check it while you are at it. Mine is under the right side cover, but that is not a requirement.
Hay
fantsybikr
O HI O
Re: IS POD lights
August 14, 2014, 02:48:25 PM »
Quote from: mrider on August 12, 2014, 05:33:56 PM
http://www.cruisercustomizing.com/kuryakyn-accessory-switches-for-master-cylinder-reservoir-covers/part/KY-7803?
VRCCDS 0252
VRCC 26284
GWRRA 329832
Rob A
Vancouver, WA
Re: IS POD lights
August 14, 2014, 07:16:37 PM »
The switch comes apart. I had the same problem so I took the switch apart cleaned and lubed it, put it back together and it works like new.
Have a good clean work area if you take it apart, there are some tiny parts in it.
1999 Interstate
mrider
Re: IS POD lights
Reply #6 on:
August 15, 2014, 05:45:55 PM »
thanks for everyones help!
=> InZane XXV
