February 09, 2026, 08:57:35 AM *
Author Topic: Dumb question regarding trailer wiring  (Read 777 times)
FLAVALK
Winter Springs, Florida
« on: August 13, 2014, 07:32:48 AM »
I have a flat 4-pole connector (yellow, brown, green, white wires) on my boat trailer and I know what each wire does.
I purchased a set of LED "PIPE-LIGHTS" to install on the trailer and there are 3-wires coming off each light (RED, BLACK and WHITE)
I assume the WHITE wire is ground, but which one is "TURN/STOP" and which one is "RUN"
Thanks in advance  Smiley
Troystg
DC
« Reply #1 on: August 13, 2014, 10:09:30 AM »
I can't tell you which is which but if they are standard 12volt you can jumper them to the battery and see.
One common, one running and one brake / turning.  Obviously the brake / turning lead will be brighter than the running light.
Troy
FLAVALK
« Reply #2 on: August 13, 2014, 10:25:21 AM »
I got it. White is ground, red is turn/stop, black is running. These suckers are BRIGHT!
