February 09, 2026, 06:56:32 AM *
Author Topic: rear wheel locks up  (Read 1611 times)
« on: August 23, 2014, 08:31:01 AM »
Been working for a couple hours to reinstall the rear wheel. Everything gets in place and I tighten the axle nut and it puts the wheel in a bind and will not rotate. I leave the pumpkin nuts loose to tighten at the end. I have tried everything and can not get it to spin free. Any ideas?
« Reply #1 on: August 23, 2014, 08:53:14 AM »
Did you remember the internal spacer on the axle, thru the wheel?  Is the brake spacer installed in the right direction?
3W-lonerider
Shippensburg Pa
« Reply #2 on: August 23, 2014, 09:55:29 AM »
is your shocks disconnected and the swing arm hanging down. if so your drive shaft is bound up. raise the swing arm and try spinning the wheel.
TJ
Lake Placid , Fl.
« Reply #3 on: August 23, 2014, 09:57:36 AM »
You're putting the drive shaft in a bine...  Jack up the swing arm some and it will turn free...
« Reply #4 on: August 23, 2014, 05:40:26 PM »
I left out that internal spacer once. It caused the exact problem Gavin is describing.
eric in md
« Reply #5 on: August 23, 2014, 06:10:00 PM »
either lift up wheel and put shocks back on  or the spacer inside wheel . let us know
« Reply #6 on: August 23, 2014, 08:58:54 PM »
+1, Hoser
« Reply #7 on: August 24, 2014, 06:32:42 AM »
 cooldude  All of the above!
My rides:
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #8 on: August 24, 2014, 06:55:59 AM »
Do not mind me much, When this happened t o me once the trans somehow went into gear
Big Mike
VRCC 23871
VRCCDS 0200
With GOD and a good attitude, there is no circumstance that I can not overcome.
« Reply #9 on: August 24, 2014, 07:15:49 PM »
Thanks guys, must have been the drive shaft in a bind. Got everything put back together and it is offically road ready.
