February 09, 2026, 06:56:29 AM *
Author Topic: Question on hydrolock  (Read 1021 times)
Pappy!
Central Florida - Eustis
« on: August 23, 2014, 12:56:35 PM »
Were the 4-cylinder wings prone to hydrolock and if not.....why?
BobB
« Reply #1 on: August 23, 2014, 01:19:04 PM »
Not sure of the answer, but if not, it's probably due to position of the carburetors.  The Valks are down draft, being tilted as they are.  That is one of the factors for hydrolock.
Dusty
Mill Bay B.C.
« Reply #2 on: August 23, 2014, 01:41:09 PM »
My 1984 Gold Wing had a electric fuel pump and inline filter. Turn off the key and no fuel.
Dusty
Michvalk
Remus, Mi
« Reply #3 on: August 23, 2014, 01:55:48 PM »
The fuel tanks are behind the motor, laying on the lower frame, and will not drain fuel without the fuel pump. So even if the carbs leak, they won't dump fuel down the throats and into the cylinders. cooldude
« Reply #4 on: August 23, 2014, 02:56:48 PM »
My GL1100 had a mechanical fuel pump.
olddog1946
Moses Lake, Wa
« Reply #5 on: August 23, 2014, 05:35:27 PM »
Mechanical or electric,,,,,they had fuel pumps, tanks were much lower on the bike and I believe they were actually below the level of the carbs.
VRCC # 32473
01 Valk Std.
02 BMW k1200LTE
cma1
« Reply #6 on: August 23, 2014, 08:27:00 PM »
yup !
« Reply #7 on: August 23, 2014, 08:36:27 PM »
Good Old mechanical. I believe it was on the RH side head. So I would think it ran off the cam there.
di1213
usa
« Reply #8 on: August 24, 2014, 03:45:44 PM »
I have a 77 gl1000 with a mechanical pump and experienced hydrolock with it. I had a leaking Carb inlet valve. Fuel will siphon from the tank through the pump if the tank is more than about half filled.
