Craigslist Add.
http://albuquerque.craigslist.org/mcy/4624106187.html
Asking $5500.00 NADA Value $6,482.00 KBB Value $7,940.00 Only. I will be putting the bike on the auto lot on base the fist part of this week.
I am selling my 2003 Valkyrie. It runs great and I have never had mechanical issues with her. The end of July took her for little more than 1000mile ride through South Dakota and Wyoming with not the slightest problem. She currently has around 45000 Miles on her. Which is just getting broke in. They say you can get 200,000 miles out of the 1520 engines with just basic maintenance(
http://www.valkyrieforum.com/bbs/index.php/topic,51704.0.html). Since I purchased her I have replaced the front tire and preventatively changed wheel bearings and Valve steam since I had the wheel off. I also flushed the cooling system. I also added an Electronic Cruise Control and a removable 5 Gallon Auxiliary Fuel tank for longer trips. It is time for an oil change. I have the stuff for the change on hand. I have not done it because as a general rule that's the first thing I do when I buy something. If you like I can change the oil before the sale or show you how it's done. The tires also have many miles left in them. There is also a very active forum community dedicated to the bike at
http://www.valkyrieforum.com/bbs/index.php they can answer any question you might have about the bike.
Sale includes:
-Factory Tool Kit
-Factory Owner's manual
-Engine Guards/Crash Bar
-Highway Pegs
-Cobra Light Bar
-K&N Filter
-Jardine Exhaust Pipes
-After Market Trigger Wheel. Designed to increases the power and performance. Also comes with the factory Trigger Wheel If you want to reinstall it.
-Windshield
-Leatherlyke Hard Cross Country Locking Saddlebags (quick disconnect)
-Dowco 50130-00 Iron Rider Black Cruiser Tank Bag. I sowed additional magnets into the bag for a better hold.
-Wired for heated Gloves (Gloves included). Hotwired Heated Gloves Size XLG.
-Wired with 2Pin SAE connector. Can be used for battery trickle charger or to plug in accessory power block (1 cigarette outlet and 2 USB connections) that can be placed in the saddle bag or tank bag for charging cellphones or powering GPS.
-CCS100 Electronic Cruise Control
-Removable 5 Gal Auxiliary Fuel Tank.
-Dual Dan-Marc fuel shut off valves. Allows quick switch between fuel tanks using electronic switch. Prevents possibility of hydro lock as the valves are off with key off.
-Kuryakyn 7803 Accessory Switch for Master Cylinder Reservoir Covers. One switch is used to switch between the main and auxiliary fuel tanks. The other 2 switches are pre wired for 10amps each with key on. The wires are already run to the fuse block area of bike for easy connection of future accessories.
-Harbor Fright motorcycle Stand/Wheel Chock. I used it mounted to a trailer but it can be used in garage as well.
I am also planning on selling my riding gear. Jacket, pants, helmet etc... Ask me about it if you are interested.
