April 29, 2026, 12:50:27 PM
Texas Chapter
(Moderator:
Daniel Meyer
D/S tire balance
Topic: D/S tire balance (Read 1323 times)
captkirk
D/S tire balance
August 24, 2014, 07:06:43 PM »
The shop that mounted my ds tire wasn't able to balance it. Is there a "best" method or product to use instead. Thanks
Re: D/S tire balance
August 24, 2014, 07:27:14 PM »
Well, how bad was it out of balance on the machine?
All my Goodyears (3) used less weight than any motorcycle rear ever did. Nearly perfect with no weights.
I have not used it but most would say Ride-On. A CT takes more than a bike tire.
BuzzKill
Lake Dallas, Tx
August 24, 2014, 07:45:25 PM »
Same thoughts here. Odd that they couldnt balance the tire. Mine has been done a couple times with 0 weights needed. I also prefer the Ride On for its balancing and puncture properties. Though it is not good with some Tire Pressure Monitoring Systems. Another option is Dyna Beads. Again not compatible with some TPMS's.
captkirk
August 24, 2014, 07:50:40 PM »
That's just it....they specialize in auto mounting....my rim /tire wouldn't fit on their balancing machine. So they used old school method similar to Kentucky windage to say it was balanced. New tire is Michelin primacy mxv-4.
captkirk
August 24, 2014, 07:51:41 PM »
Thanks to you both!!
