February 09, 2026, 06:56:24 AM *
Author Topic: Spoonland Adapter  (Read 979 times)
rswitzer
« on: August 25, 2014, 05:23:45 PM »
I can't find the L shaped bolts for my spoon land adapter, so I think the cheapest thing to do is try and buy some from Ross Spoon land, but an email sent to him came back to me. Does anyone know how to get ahold of him?
Bob
« Reply #1 on: August 25, 2014, 06:32:21 PM »
Sorry I don't know what a spoon land adapter is  Undecided
« Reply #2 on: August 25, 2014, 06:55:33 PM »
Hell if I wasn't equiped to make them I'd just buy some long bolts at Home Depot and heat them up with a torch and bend them.  5 minutes maybe.
Cracker Jack
« Reply #3 on: August 25, 2014, 07:29:33 PM »
He was probably asking from someone who knew. uglystupid2
« Reply #4 on: August 25, 2014, 08:02:44 PM »
Duh ok 2funny 2funny
Maybe someone could enlighten me. Is it a hack adapter or something of the sort?
Grumpy
Tampa, Fl
« Reply #5 on: August 25, 2014, 08:51:13 PM »
Ross Spoonland was one of the first to make metal Valkyrie lift adapters, made one that mounted on a floor jack, and another that used a motorcycle lift.
rws
1997 Valkyrie Tourer
North Dakota
« Reply #6 on: August 25, 2014, 09:52:44 PM »
1/2" bolt heated and bent like this
Original VRCC Member Number 697
1997 Honda Valkyrie Tourer - 2019 Honda CRF450L - 2021 Honda Rebel 1100 DCT
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #7 on: August 26, 2014, 05:41:36 AM »
I just use a 1/2 clevis pin with at ring on it. They come with the ring on them and a ball in the  pin. Just cut to fix for length
« Reply #8 on: August 26, 2014, 07:56:38 AM »
You might contact this guy and see if he can sell you some....
http://www.ebay.com/itm/LOOK-VALKYRIE-HONDA-ORIG-RIVCO-JACK-ADAPTER-Save-money-with-ea-use-/170854771001?pt=Motorcycles_Parts_Accessories&hash=item27c7bce939&vxp=mtr
Slvrvalk1
« Reply #9 on: August 26, 2014, 02:48:21 PM »
I bought a hinge set for a gate.  I had to grind a collar off one of the pins.  This was a more expensive fix then simply bending a bolt.  I forgot to take the original pins out before I went down the road.  Things like that happen when you get older> Embarrassed
Dave
YoungPUP
Valparaiso, In
« Reply #10 on: August 26, 2014, 06:18:44 PM »
I made one of these a fey years ago. Go to your local hardware store and buy a squared "u" bolt.  cut it in half and you get 2 for the price of one.   There's  a second one that I made that uses  2 tabs welded on to the sides of the adapter that uses a piece of round stock that  has a washer welded on one end and is cross drilled for a cotter key on the other.  As for the stud for the floor jack (if that's the one you're building) I got a 3 point hitch stud from tractor supply that fit my jack for about 4 bucks.  It was a bitch to cut (its very solid steel). Cut  it to the length that I needed and then cut threads into my base plate and threaded then welded it into place.  Waaayyy overkill but I'm not fond of dropping a 900lb motorcycle on the back of my head while I'm working on it...
99 STD (Under construction)
