Dak44312
« on: August 27, 2014, 07:36:26 PM » |
Has anyone replaced their engine guards with a new set? I recently bought a crashed I/S and the bars were bent from the ditch the bike was laid into. I bought a set of new ones (never used) and a couple of the bolts are going to take a little persuasion to get the holes lined up- nothing that can't be done with some pressure in the right area, but just wondering if that's normal. A dealer assessed the bike before the previous owner sold it to me and frame damage was not on the quote sheet.
So, was the tooling somewhat inconsistent on the bars, or should they just fall into place?
TJ
« Reply #1 on: August 27, 2014, 07:46:16 PM » |
LEAVE EVERYTHING LOOSE TILL YOU GOT ALL THE BOLTS STARTED....
Dak44312
« Reply #2 on: August 27, 2014, 07:58:08 PM » |
Yeah, I'm doing that already and I've tried starting different bolts first.
« Reply #3 on: August 27, 2014, 09:25:53 PM » |
I had the same issue on a Valkyrie I had to put back together after a friend cartwheeled it at 50 MPH. Keep trying and grunt hard while tweeking.
« Reply #4 on: August 27, 2014, 10:45:14 PM » |
When I loosen my original engine guards up, on unwrecked bikes, they do not go back together easily. I have had to use a crowbar to pull a mount to line up with the hole (without loosening all bolts). My guards have hit the ground in tipovers but no wrecks; they are scraped, but not bent or deformed that I can see.
My point is, I believe your engine guard fitment is pretty SOP, and doubt your frame is bent.
The advice to install all bolts loosey goosey, then go around multiple times turning them in, is sound.
Paxton
« Reply #5 on: August 28, 2014, 02:53:20 AM » |
"... but just wondering if that's normal." ======================= Yes it is normal. They are a bitch to install.
J. Paxton Gomez
1966 First year Bronco... 302 CI V8 1975 First year Chrysler Cordoba... 360 CI V8 1978 Honda 750F / Cafe Racer 2000 GL1500CY Fast-Black Standard Solo Rider
So Cal... 91205
« Reply #6 on: August 28, 2014, 04:14:15 AM » |
 It may still take some persuasion.
Daniel Meyer
The State of confusion.
« Reply #7 on: August 28, 2014, 04:23:43 AM » |
Ain't telling how many I've changed...but it's normal.
CUAgain, Daniel Meyer
Dak44312
« Reply #8 on: August 28, 2014, 05:48:04 PM » |
Thanks- makes me feel better. Got 'er installed tonight. Saved the hole where the two bars meet for last. Seemed to be the best way to go, at least for this particular bar. Just need a red/black fairing and a pair of lowers and I can finally stop wearing a backpack and driving my Standard on trips!
Brewer
« Reply #9 on: August 28, 2014, 07:06:08 PM » |
Mine just went on. Strangely easy.... left side front bolt in first and it all lined up. Based on what I have read this is rare.
Brewer - it is a hobby
Big Mike
I can not remember my last bad day
Taylor MI
« Reply #10 on: September 02, 2014, 08:00:51 PM » |
Engine guard should need no persuasion to fit properly. My guess is that the frame is tweaked a bit the bike was wrecked
Big Mike VRCC 23871 VRCCDS 0200 With GOD and a good attitude, there is no circumstance that I can not overcome.
