February 27, 2026, 03:30:36 PM *
Author Topic: Fork Seal Cleaning Trick  (Read 806 times)
signart
Crossville, Tennessee
« on: August 28, 2014, 12:20:50 PM »
Guys that have cleaned fork seals to attempt repair on minor leaks.
Do Valkyries have dust shields that need to be lowered for this procedure? Also is a 2 liter Coke bottle too thick to use in making a cleaning tool out of?
« Last Edit: August 28, 2014, 12:22:22 PM by signart » Logged
bentwrench
Philadelphia,Pa.
« Reply #1 on: August 28, 2014, 12:27:05 PM »
The dust seals come down pretty easy.try some old 35mm neg. ,got all kinds of junk out of mine several k miles with no problems.
garyheskett All 49 x 3 st.louis
St. Louis, Missouri
« Reply #2 on: August 28, 2014, 01:36:16 PM »
I've done the "film trick" three times now on the 97 Standard that I have.  I did not remove the chrome shield or the dust seal.  I just shoved some 35mm film into the fork and worked my way around.  It has worked every time (and now have 137,000 miles on it).  Removing the chrome shield (just a couple bolts) and dropping the dust seal is probably the better way to do it.  I bought the Sealmate little tool ($5), but I like the 35mm film better. Way easier than replacing the seal.
« Reply #3 on: August 28, 2014, 03:36:20 PM »
The dust seal comes right down easily with a tiny flathead screwdriver.  It's hard enough to saw your thin cleaning tool up and down and around getting all oily without leaving the dust seal in place.
I cannot answer the coke bottle question, thou recall some writing they chopped up a plastic bottle of some sort to make such tool.
First time, I did not remove my rock guards, later I did and it made the job easier... and I did a much better job.  I see no reason to pull the fender thou.
Rio Wil
« Reply #4 on: August 28, 2014, 04:08:00 PM »
Yep....the one made from a coke bottle works fine.....a bit sturdier than 35 mm film.
signart
« Reply #5 on: August 28, 2014, 05:08:59 PM »
That's what I was kinda thinking, it would be sturdier. Don't want to do damage, not my bike. Thanks everyone for response.
« Reply #6 on: August 28, 2014, 07:42:16 PM »
To me it seems easier to just remove the fender than the rock guards cooldude
« Reply #7 on: August 28, 2014, 11:31:23 PM »
Once you figure out the right (small) tools, the guards are easy;  one nut a 1/4" stubby ratchet/socket, the other a ratcheting box wrench, high and low.  But be careful, the small nut will slip down inside the fender/fork mount and it takes a magnet to retrieve it.  Like the interstate bulbs, you have to do the job by feel.
