November 26, 2025, 04:12:34 AM *
Author Topic: Barnett heavy clutch spring  (Read 707 times)
« on: September 01, 2014, 11:18:29 AM »
any benefit to using one?
pros and cons?
Thanks to all.  cooldude
Valkpilot
What does the data say?
Corinth, Texas
« Reply #1 on: September 01, 2014, 11:55:42 AM »
pros and cons?
No experience with the Barnett, but a new OEM spring seemed pretty stiff to me.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #2 on: September 01, 2014, 12:49:49 PM »
just finishing reading about 20 posts, just new OEM spring seems to be the way to go.
reading all of the posts it seems there are a lot of 97-98 bikes some low miles like mine having the damper plate go bad.
was there some type of problem those yrs?
other yrs have 100k+ miles and no problems including supercharged bikes.
Valkpilot
Corinth, Texas
« Reply #3 on: September 01, 2014, 04:36:13 PM »
Problem has been ascribed to bad plate assemblies from a sub-component vendor.  It does seem to happen most often with 97 and 98 models in the 60k mile range.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
« Reply #4 on: September 01, 2014, 05:14:29 PM »
Thanks VP
goldwings those same yrs also have same problem after reading some GW forums.
I hope the new damper plate I just ordered is the new and improved one.   Undecided
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #5 on: September 02, 2014, 05:46:40 AM »
I had one in a Valkyrie and did not like it. I pulled it out and went back with the stock one
