November 26, 2025, 04:12:32 AM
crash bar
Topic: crash bar (Read 824 times)
matt
Derry New Hampshire
crash bar
September 03, 2014, 02:59:21 PM »
Okay so today is not a good day to work on valk figure I would che k intake tubes see if any stains need to remove chrome plug runners well left side back bolt had an extension from head to cover well it broke in the head(gotta get a new drill bit) so on to right side remove air horns to get chrome plug cover off and drop nut behind timing cover and block. Question can crash bar be removed or will frame move? If I move it out of way hoping to find nut. Thanks for any input.
Re: crash bar
September 03, 2014, 03:11:40 PM »
Yes, it can come off no problem. It can be a bear going back on however...will probably not want to line up very well without some persuasion. Keep everything loose before tightning all of the bolts when putting it back on.
Re: crash bar
September 03, 2014, 03:21:26 PM »
Might try a magnet on a thin screwdriver to get it out.
matt
Derry New Hampshire
Re: crash bar
September 03, 2014, 03:50:16 PM »
Cannot even see it, it was in front corner by smog pipes went to get it and it fell deeper I figure of I move bars I might see it. Plus it will give me time to get ready to drill broken bolt in head lol
matt
Derry New Hampshire
Re: crash bar
September 03, 2014, 04:26:19 PM »
Thank you bar is off got nut bar is back on.. another day I will try and drill broken bolt back corner left head it holds smog pipes on and ext for spark plug covers chrome
=> InZane XXV
