dr.danh
« on: September 07, 2014, 05:01:25 PM » |
Put rear wheel on all looks good brakes etc. spacers in place as suppose to be and wheel turned ok Until as tighten the axle nut it will faint pop a little then pop as tighten. Like a press would do. And the wheel gets harder to turn. When torques to spec. The wheel was hard to turn. I took all apart. checked bearings, spacers right. Still same again. Any suggestions.
« Reply #1 on: September 07, 2014, 05:18:37 PM » |
Why did you have the wheel off in the first place? Was it just a tire change? I don't even want to venture a guess with out a little more back ground.
« Reply #2 on: September 07, 2014, 05:26:41 PM » |
Make sure the spacer is in the pumpkin it's a round tube with a flared end on it. Goes in the center and axel goes through it. Had one fall out of the pumpkin once and didnt realize it and the wheel did exactly what you are describing.
« Reply #3 on: September 07, 2014, 05:38:43 PM » |
Yeah my thought as well, but I wanted to be sure no other "wheel" work was done. Only other thing could be the brake caliper bracket is some how caddywhompiss.
« Reply #4 on: September 07, 2014, 05:41:20 PM » |
If it does happen to be that spacer, the flared end goes toward the wheel.
« Reply #5 on: September 07, 2014, 05:46:20 PM » |
I would just about bet it is the flared tube for the axle is missing. Please don't ask me how I now this. It is easy to miss it. Hoser
« Reply #6 on: September 07, 2014, 07:43:20 PM » |
If bearings were changed, the internal spacer between the two wheel bearings could have been left out
PAVALKER
Pittsburgh, Pa
« Reply #7 on: September 08, 2014, 05:47:21 AM » |
And that might give that pop pop sound as well... Left Spacer in the correct way?
John
« Reply #8 on: September 08, 2014, 05:56:28 AM » |
Regardless of the cause, that pop, pop sound
is not good, and sure does indicate something
was breaking. Exactly what, will be discovered
with an inspection, after the cause (of the popping)
is revealed.
« Reply #9 on: September 08, 2014, 06:03:57 AM » |
You can also get a pop or snapping sound from a bearing in a wallowed out seat. With that, the bearing isn't sitting in a perfectly round seat and will move around. Might need to have that checked out.
dr.danh
« Reply #10 on: September 08, 2014, 06:59:46 AM » |
Om thanks for alll the help. I had all spacers in. Only think is maybe the if can would be a prob. is the one in the pumpkin may had got turned around. I wont be able to dissemble again for a bit to ck. Thanks
97Valk_CT_Euless
« Reply #11 on: September 08, 2014, 07:06:58 AM » |
I had something similar happen when I was trying to put too much paste in the splines, out of paranoia. Just had put a bunch of work and money in to the final drive because of the PO's lack of spline maintenance. New O-rings, and way too much moly paste will definately tighten p the rear wheel.
« Reply #12 on: September 08, 2014, 09:59:58 AM » |
I agree with the others. Something is wrong. Sounds to me as though the wheel bearing spacer is missing. But, regardless, I'd recommend not tightening it any more and take it back apart ASAP.
« Reply #13 on: September 08, 2014, 10:04:36 AM » |
the one in the pumpkin cannot get turned around. It can get left out but you wont get anything together if you had put it in backkards, it would be sticking out way too far to get the wheel on
