March 14, 2026, 05:36:38 PM *
Author Topic: Headlight Modulator Wiring Problem (Yes Russ ... I put it on the Tech Board)  (Read 5852 times)
Harv
One Bad Motor Scooter
Des Moines, Iowa
« on: September 08, 2014, 06:17:41 PM »
I installed a new headlight bulb because my high beam was burned out. The connection to the modulator was a little loose and just seemed pretty rinky dink to me at the time but it had always worked before the high beam burned out so I just put a little better tape job on it. My modulator hasn't worked since so today I thought I'd try to figure out why it wasn't working. To make a long story short in taking it apart the wires came out of the plug and I don't know how it was hooked up. There are only 2 wires and there are 3 holes in the plug. Electrical is not my thing! Anyone know how this should be wired? I did try a couple different combinations but figured I might blow something if I hooked it up wrong so I thought I'd ask for help on the board. Thanks for any help you can give.
https://plus.google.com/photos/112250084788105832387/albums/6056869974996300257/6056869996520753282?banner=pwa&authkey=CKS3w8vLhZ7SkwE&pid=6056869996520753282&oid=112250084788105832387
Harv Wink
« Reply #1 on: September 12, 2014, 07:00:36 PM »
Hey Harv, did you get your problem resolved?
Keep us posted Brother.
You might be ornery, but we still love ya.
 cooldude cooldude cooldude
« Reply #2 on: April 18, 2015, 05:32:48 AM »
Harv, did you get this issue resolved?
Harv
Des Moines, Iowa
« Reply #3 on: April 18, 2015, 07:58:53 AM »
No, I never did get it working. It's probably trashed. It is still hooked up so I suppose I better take it off in case it could cause me problems .... but maybe it will miraculously fix itself!  cooldude
Harv Wink
« Reply #4 on: April 21, 2015, 07:35:34 AM »
I told you to call my son, so now the ball is back in your ball park.
So quit complaining, OK?
Harv
Des Moines, Iowa
« Reply #5 on: April 21, 2015, 11:36:56 AM »
Thanks and I will but who's complaining?
Harv Wink
« Reply #6 on: April 21, 2015, 11:41:39 AM »
ALL OF US........................
