April 29, 2026, 09:05:19 AM *
Author Topic: Belly pan for 2014 Valkyrie  (Read 5740 times)
Etlonghorn
East Texas (Canton area)
« on: September 09, 2014, 07:54:30 PM »
Just purchased a new 2014 Blue Valkyrie and would like to put a belly pan on it. Since the Valkyrie and the GL1800 Goldwing have the same Engine and transmission would the GL1800 Goldwing belly pan fit the Valkyrie?
« Reply #1 on: September 09, 2014, 08:55:01 PM »
I have an 05 wing with a belly pan. I think you'll just have to get 2 bikes side by side to compare.
« Reply #2 on: September 09, 2014, 09:38:17 PM »
Good suggestion sandy.
IMHO, & it isn't worth much, I doubt if it will fit without a ton of modifications.
Now, my question: why do you want a belly pan on it in the 1st place?
It would be a pain in the arse to do work on the bottom end, like oil changes and etc.
Like I said, just IMHO.        Roll Eyes Roll Eyes Evil Evil angel angel
jimmytee
Elizabethtown,KY
« Reply #3 on: September 10, 2014, 02:51:15 AM »
I don't know if they'' fit, but I'm guessing that yes they would because under there, I believe they are the same. Here is a link to Wingstuff page and several options.
http://wingstuff.com/shop/?keyword=belly+pan
Why? for protection from road debris. The coolant reservoir is plastic and is under there.  I have not added one yet , but it is a thought. As far as oil changes, I believe most of them have a easily removable panel for that purpose.
There is at least one made from diamond plate that actually can be used as jack surface.
Sorcerer
Brooklyn Center MN.
« Reply #4 on: September 10, 2014, 06:31:22 AM »
On the gl1800s the over flow tank is behind, under motor. The motor protects it for the most part, but not completely. At 1765 miles on my F6B the alum duck tape Honda puts on it had hole all the way through the alum duct tape from gravel hitting it. I put the alum belly pan on. If / when I need to replace it I will go with the stainless pan with the air craft fasteners that Wing Stuff has. Small steel Allen screws in alum is going to be trouble. Those little screws that hold the front cover are easy to strip the Allen head. First oil change I stripped one Allen head and had to drop the belly pan to remove the screw. As of now the belly pan is a consumable part as I am grinding the edges.
six2go #152
Ft. Wayne, IN
« Reply #5 on: September 10, 2014, 07:31:18 AM »
This!!!
I put the Diamond Plate one from Wingstuff on my F6B. After what happened to EEEZZRIDER in Florida last Fall (on his Valk) as a result of road debris, I wasn't taking any chances. They don't interfere with oil changes at all. They are two piece and the front part removes to access the filter & drain plug. This might be the best but most overlooked accessory for the new 1800's.
« Reply #6 on: September 10, 2014, 08:01:07 AM »
That would sell me on one. I was looking under there today. I don't have a clue
about how to put this thing on a jack. And that tape looks like it belongs
on something someone made in their back yard  crazy2 ...
Anywho... any of you who've jacked up the new Valkyrie please talk about it...
-Mike "off to read the diamond plate ad copy..."
I'm back...
I can't really tell what the back leg of the jack is on...
« Last Edit: September 10, 2014, 08:09:32 AM by hubcapsc » Logged
Xyzzy
Arkansas
« Reply #7 on: September 10, 2014, 06:11:44 PM »
An email to Tulsa:
Mike,
I don't believe it will, it fits under the exhaust heat shield on the GL and over the bottom of the lower cowling.
I haven't really looked at the new Valkyrie to give you a honest answer.
It really doesn't limit cornering much at all.
There are some copies out there, but, ours is the Original for the GL 1800
Sorry for the delay in responding
Regards
Allen
-----Original Message----- From: M Vang
Sent: Thursday, August 14, 2014 11:42 AM
To: allamericanprod1@twc.com
Subject: 2014 valkyrie
does your standard gl1800 belly pan fit the new valkyrie?
also, do you have any close-up pictures of the pan installed on a wing?
i've never seen one installed before so i am curious how much it hangs
down, particularly in the corners
i have seen other belly pans on wingstuff.com but i hear you guys are
the ones who designed the first
thanks for your time!
Etlonghorn
« Reply #8 on: September 19, 2014, 06:52:53 AM »
FYI - purchased GL1800 Goldwimg Belly Pan ( black)  fom Big Bike Parts. Fit with no problems, looks good . Took before and after pictures, but can't get them to load.
imrubicon
« Reply #9 on: September 22, 2014, 05:04:31 PM »
Had one on my wing and they look nice and keep crud off the bottom.
Nice to know they are pretty much the same bottom
mrtappan
« Reply #10 on: September 25, 2014, 07:36:24 AM »
I just bought a diamond plate one from Wingstuff and it shipped today.  I'll get some pics of it once it comes in if no one has added any yet.
Profile deleted.
