February 09, 2026, 10:54:54 AM
How do you test an alternator ?
Topic: How do you test an alternator ? (Read 733 times)
Bugslayer
Lubbock, Texas
September 13, 2014, 12:29:02 PM »
Does it have to be off the bike, or is there a way on the bike?
Re: How do you test an alternator ?
September 13, 2014, 01:01:29 PM »
Do you have a volt meter? Commonly called a VOM (volt ohm meter). Measure the "key off" voltage. ~12.2 ---- "key on" = ~12.1 ---- Start bike and slowly rev engine while measuring voltage. It should increase to ~14.2 ----- This should tell if the alt is charging.
BTW: ~ means approximately
RONNIEB
NEWCASTLE, OKLAHOMA
September 13, 2014, 01:56:26 PM »
What Sandy said
1999black standard; 2000 black tourer; 1999 red/black interstate
September 13, 2014, 02:54:29 PM »
Ah, but where to measure the voltage at?
I think he is saying positive lead to positive terminal of the battery. Negative can go to any ground, but I would also use the battery terminal.
Like mentioned, this will show if there is power going to the battery.
If the reading doesn't change from ignition key off, and the bike revving at higher RPM, then power is not going to your battery. Then you need to test for power output at the alternator.
Ask again after you get some more information.
Bugslayer
Lubbock, Texas
September 13, 2014, 03:32:13 PM »
Good info..... Thanks!
