January 29, 2026, 10:17:08 AM
Petcock
Topic: Petcock (Read 1751 times)
Ebony Red
MN Chapter Rep
Red Wing MN
Petcock
August 12, 2009, 01:22:44 PM »
My '99 I/S has it's stock petcock now with 47k on the clock. I have never had a problem with it. Also don't shut off the petcock when I'm parked.
When running on my last tank it started missing with 2 bars showing on the gauge. I then switched to reserve, and back to on, it then cleared up.
Any ideas? - I know Pignel would be an option. Or would a rebiuld kit be the answer.
Re: Petcock
August 12, 2009, 06:45:11 PM »
You could rebuild it with a cover set (vacuum side parts) but eventually the fuel switch side will wear out and you will need a new one....OEM is more than a Pingel. I did the rebuild thing then just replaced it with the Pingel.........wished I didnt waste the time rebuilding. Make sure the tank is clean before you but the new valve in
rmrc51
Palmyra, Virginia
Re: Petcock
August 13, 2009, 11:49:44 AM »
I'll also chime in for the Pingel!!
I rebuilt mt stock petcock and she developed a slow leak. I figured why bother fooling with it and opted for the Non-Vacuum Pingel.
Simplicity at it's finest!
VRCC # 30041
