February 09, 2026, 02:51:22 PM
Oil light - both on and off
Topic: Oil light - both on and off (Read 841 times)
sawdustar
Conway, AR
September 23, 2014, 11:15:01 AM »
I've noticed that my oil light comes on with the ignition switch "sometimes" and I think it should be coming on "every time" I turn on the ignition switch. Y'all will probably have to educate me on this but seems to me that something is needing replaced or repaired?
Thank You,
Dennis
Daniel Meyer
The State of confusion.
Re: Oil light - both on and off
September 23, 2014, 11:19:46 AM »
Should come on with the switch and go out immediately on starting (standard).
Could be the oil pressure sensor, the bulb or wiring, or perhaps a loose ground up there somewhere...
I would check to see if there's voltage to the bulb with the key on and engine not running. If so, there's a bad bulb, socket, or ground...
CUAgain,
Daniel Meyer
