November 26, 2025, 04:23:45 AM *
Author Topic: Turn Signal Flasher  (Read 955 times)
Harv
One Bad Motor Scooter
Des Moines, Iowa
« on: September 24, 2014, 04:40:19 PM »
Where is the turn signal flasher located on a 98 Standard?
Harv Wink
dragon96
« Reply #1 on: September 24, 2014, 05:44:33 PM »
In front of battery !
Gryphon
Resistance is futile; if less than 1 ohm.
Fulton, MO
« Reply #2 on: September 25, 2014, 07:47:47 AM »
You can get to it by removing the left side cover.  Helps to remove the reservoir.  Long skinny fingers is also a plus.  Other than that, it's not hard to change.   Roll Eyes
« Reply #3 on: September 25, 2014, 12:00:50 PM »
Mike, check your email box.
