November 26, 2025, 04:24:23 AM *
Author Topic: Double Dark?  (Read 1008 times)
« on: September 24, 2014, 08:13:13 PM »
Thinking about trying double darkside.  I love Avon Cobras on front but they aren't cheap and I rip through them on the chip seal around here.  Can't even get 10k out of them.  Is there a good handling "favorite" (rear) tire similar in size to the OEM 150/80-17 for front darkside?  Is anything close in handling to the Cobra?  I'd like to hear from those who have tried double darkside, what tire they used, if they like our hate it and why?  I don't want to sacrifice cornering, etc. to save some bucks.
« Reply #1 on: September 24, 2014, 08:57:46 PM »
I've got 4k on a Yokohama avid ascend 195/60 on the rear and a Michelin pilot Activ 150/70 rear mounted reverse on the front with 2k on it. It's early to judge but I think this might be my best combo yet. Time will tell. I don't ride super aggressive but they feel great to me. Haven't had the the front in rain yet though.
Led
Wisconsin
« Reply #2 on: September 25, 2014, 01:57:05 PM »
I am curious, as to why you would run the CT "reverse" on the front. "Directional" tires are designed to shed water out the back. If it is reveresed, could you just build up more water in FRONT of the wheel, of which I do not believe would be a good scenario?
Just curious as to your reasoning. Maybe there is something here, I am not getting.....??
« Reply #3 on: September 25, 2014, 02:05:22 PM »
Not a CT on front.  It's a rear MT reversed on the front.
« Reply #4 on: September 25, 2014, 02:10:35 PM »
To quote myself:
Regarding tire construction, tread patterns, and directionality:
The main reason why the direction of a motorcycle tire is specified is because of the way the tire is constructed.  Where the belts overlap there is a potential weakness.  The accelerating or braking forces will either be trying to separate the lap joint, or push it together.  Because the dominant force on a rear tire is acceleration rather than braking, the tire is oriented so the lap joints are pushed together.  The same tire on the front wheel should be mounted backwards because the force on the tire is all braking and no acceleration, and by changing the direction we continue to push the joint together.  How much of a concern this really is is open for us to debate or for a motorcycle tire engineer to settle.
With directional tread patterns and rain, if the tire's contact patch is not moving faster or slower than the road surface (i.e. the tire is not sliding due to acceleration or braking forces), the direction of the "V" has no bearing on how well it evacuates water.  Water is simply squished out from under the tread blocks and into the nearest groove with capacity to take it.  When the back tire is slipping due to acceleration, the "V" should point towards the back of the bike at the road surface.  It acts the same as a tractor tire slipping in mud, directing the fluid towards either side of the tire, rather than scooping it towards the centre of the tire.  When the front tire is slipping due to braking forces, the "V" should point towards the front of the bike at the road surface.  It acts like a "V"-shaped snow plow, pushing the fluid towards the sides, rather than scooping it towards the middle.
For these reasons, if I were to try mounting a designated rear motorcycle tire on the front of my bike, I would reverse its intended mounting direction.
« Reply #5 on: September 25, 2014, 03:43:44 PM »
Yes it is. Sorry I guess I wasn't clear in the way I worded it. The Yokohama CT on back is in the correct rotation. The Michelin rear activ is backwards of the rotation arrow. I did that because it looked like it would shed the water better. Some don't though with good results. It just looked to me the best way. Like I say so far this is my favorite combo.
« Reply #6 on: September 25, 2014, 05:14:08 PM »
Thanks for the info meathead.  I like the looks of that tire, it has a sporty tread design.  I may try it with the Austone on back.
Firefighter
Harlingen, Texas
« Reply #7 on: September 25, 2014, 05:16:50 PM »
Hey Valkorado, wanting the same, but I don't want to go any smaller tire. The only REAR tire I have found in the 150/80/17 is the Bridgestone Exedra g701 Radial, expensive and the only review I have seen so far was not good. Have not had time to look much yet.  Firefighter
2006 Honda Sabre 1100
2013 Honda Spirit 750
2002 Honda Rebel 250
1978 Honda 750
« Reply #8 on: September 25, 2014, 06:19:31 PM »
The G701 is a front . I've had 2 and they were good tires and got about 13k out them. The G702 are the rears but they don't have them in 150/80/17.
Fla. Jim
« Reply #9 on: September 25, 2014, 07:28:03 PM »
Rear tire I am currently running on front to go with my Michelin Hydroedge rear. Is a Michelin Pilot Activ Rear Tire - 130/70-17H.
Ran a couple of K491 Dunlops and got over  30k apiece with them. This current Michelin front rides smoother and seems to be as tractable.
Firefighter
Harlingen, Texas
« Reply #10 on: September 25, 2014, 08:06:49 PM »
Been looking at the Bridgestone G701, says rear tire. Same one you used?  Firefighter
1978 Honda 750
« Reply #11 on: September 26, 2014, 05:40:11 AM »
I tried to put up a link but couldn't get it to work. The G701 is a front and the G702 is the rear. But the 702 doesn't come in the right size to put up front. I've had a couple of the 701's and they were fine. Got about 13k out of them. cooldude
