November 26, 2025, 04:23:46 AM
Starter noise
Topic: Starter noise (Read 908 times)
forjj
Luray, VA
Starter noise
September 25, 2014, 06:43:19 PM »
When I bought my 2000 I/S a few years ago, the started sounded different than the 97 standard I had before. It starts fine, just has a clicking sound when I engage the starter. I have ridden the bike about 10k miles, and I have never had a problem with it starting, so I am not sure I want to do anything about it, unless it is an easy fix... Any ideas???
jj
2000 Interstate Blue/Silver
2005 Corvette
1989 F250 Diesel
1979 Ford 1100 Diesel Tractor
"I don't know where I'm going, I see no reason in being late"
Re: Starter noise
September 25, 2014, 07:26:09 PM »
How many miles do you have on the bike total, and what kind of work are you willing to do?
My first thought was a missing tooth from a past Hydrolock.
I would pull the starter sometime you aren't using the bike (winter), clean it right up. Then inspect in the engine case the starter gears, and see if any teeth a missing.
If nothing found, then at least you've done some pre-maintenance on the starter.
Re: Starter noise
September 25, 2014, 08:19:59 PM »
I'd first check to see if all the mounting bolts for the starter are tight. A loose starter will make a similar sound. But at the same time, if it happens to be loose that should make you wonder why it was removed to begin with.
forjj
Luray, VA
Re: Starter noise
September 26, 2014, 04:48:43 PM »
The bike has about 22k miles on it. The sounds hasn't changed on it since day one, if the mounting bolts are loose, wouldn't it get worse/looser over time? I was hoping it was something easy, but I guess I will pull the starter this winter. I am thinking about selling the bike this spring, so I figured I better fix it before I try to sell...
2005 Corvette
1989 F250 Diesel
=> InZane XXV
