July 12, 2025, 07:41:40 AM *
Author Topic: snubber  (Read 3206 times)
TrapperJ
« on: August 13, 2009, 08:22:32 AM »
On an old post it was recommended to put a snubber in the vacuum line to the petcock. What is a "snubber"?
« Reply #1 on: August 13, 2009, 09:38:45 AM »
The vacuum from just one cylinder is a pulse vacuum. It pulls and stops with each intake/comp/combustion/exhaust stroke. A snubber is a small orifice device to make the vacuum a more constant pull all the time.
Madmike
Campbell River BC, Canada
« Reply #2 on: August 13, 2009, 09:42:50 AM »
also called a pulsation dampener ............
Farther
Quimper Peninsula, WA
« Reply #3 on: August 13, 2009, 09:53:07 AM »
Where can a person get one of these things?
~Farther
TwoDogs
1999 Interstate
Waco, TX
« Reply #4 on: August 13, 2009, 11:10:13 AM »
One of the posts in the archives has a link to Mcmaster-Carr with part numbers. I'll sell you mine for $15 + shipping. I went electric and disabled the vacuum part of the petcock instead. Never installed the snubber. Email if you're interested.
If God dwells inside us like some people say, I sure hope He likes enchiladas, because that's what He's getting.  - Jack Handey
Daniel Meyer
The State of confusion.
« Reply #5 on: August 13, 2009, 11:27:39 AM »
There is one built into the cover...which is why they give you a new one in the rebuild kit.
CUAgain,
Daniel Meyer
TrapperJ
« Reply #6 on: August 13, 2009, 11:51:44 AM »
I went to my honda dealer and they no longer sell petcock rebuilding kits.
rmrc51
Palmyra, Virginia
« Reply #7 on: August 13, 2009, 11:55:38 AM »
Get a Pingel. You won't be sorry. IMHO.
VRCC # 30041
Daniel Meyer
« Reply #8 on: August 13, 2009, 12:05:07 PM »
Your dealer is not correct.
COVER SET,rooster
16953-MBZ-B51  (replaces 16953-MV9-000)   $27.22
CUAgain,
Daniel Meyer
« Reply #9 on: August 13, 2009, 12:52:14 PM »
Quote from: John U. on May 05, 2009, 10:09:04 AM
Many thanks  CA ExhaustCoatings for the info and source. This is the first new (to me) idea I have heard that might help mitigate petcock troubles, and their terrible consequences. Do you think there is any need for the stainless snubber? I guess I can find the hose barbs to hook it up locally.
So where in South Jersey are you? I'm in Lower Delaware. Let me know if you're heading my way.
John
Brass is fine, that is what I used. Install it with the disc towards the intake manifold. I installed it 3-4" from the manifold connection just under the carbs. I secured it to the carb support bracket.
 http://www.chemiquipproducts.com/  download the catolog.
 Finding a female 1/8" hose barb is the hard part to find. mc'master has both.  http://www.mcmaster.com/#44555k123/=1qq4na   $2.51
http://www.mcmaster.com/#44555k128/=1qq4y9   $8.69  snubber .5 micron disc http://www.mcmaster.com/#4034k11/=1qq5ag   $1.00
« Reply #10 on: October 26, 2009, 05:28:19 PM »
I tested it, it is a very poor one if that is what it is. It acted more like a check valve that bleeds down. if anything it doesn't work well for extreme on/off vacuum conditions during on/off throttle.
5_19
Dublin, Texas
« Reply #11 on: October 26, 2009, 05:48:27 PM »
The petcock is fully open at 2"HG vacuum when I checked it's opperation. Your vacuum level is above 6" or higher almost all the time, doesn't this means that the diaphram is all the way open and the pulsing has no effect at all?  ???
TJ
IBA # 45723
2009 BMW R1200 GSA
« Reply #12 on: October 28, 2009, 03:57:00 AM »
Another way to dampen the pulse's would be to connect several intake lines together..
« Reply #13 on: October 28, 2009, 09:37:43 PM »
COVER SET,rooster
[/quote]
My local stealer knows absolutely nothing about Valkyries......its like a Valkyrie isint even a Honda to them.  I never trust their opinion or answer.......they usually ask me about stuff, and when I buy a part there they almost just give me the computer so I can find what I want.......very sad
BOZ
« Reply #14 on: October 30, 2009, 05:44:39 AM »
Prior Quote:
"Brass is fine, that is what I used. Install it with the disc towards the intake manifold. I installed it 3-4" from the manifold connection just under the carbs. I secured it to the carb support bracket."
I'm not sure what you mean when you say "Install it with the disc towards the intake manifold." I got the items you recommended (as I've had a couple of stock petcock diaphrams go bad) and I'm not sure I see exactly see what you mean by the "disc" when looking at the snubber. Is the "disc" the flat end of the snubber?
Would appreciate any additional clarification.  Smiley
« Reply #15 on: October 30, 2009, 07:47:10 AM »
Prior Quote:
the one end should have a disc, I guess u could call it the flat end, the other end u should be able to look down into it. check out the manufactuter link I provided also for clarification. I hope that helps u.
Puffs Daddy
« Reply #16 on: October 30, 2009, 11:35:44 AM »
COVER SET,rooster
Thanks. I was under the impression that was a part number for a condom.
