November 26, 2025, 04:41:27 AM *
Author Topic: Seat removal  (Read 3341 times)
Yfx4
North of Dallas TX
« on: September 27, 2014, 05:26:52 AM »
How do I get  the seat off?????
 I used the key for the front.  I removed the rear bolt attachment.
There is a middle attachment I can't find.
Oh,  yeah,  '99 interstate.
1999 Valkyrie Interstate
2007 VTX 1800R
DW rides a 2010 Spyder RT
Michvalk
Remus, Mi
« Reply #1 on: September 27, 2014, 05:46:29 AM »
There is no rear bolt attachment on an interstate. Turn the key, lift the front of the seat out of the latch, and pull toward the tank. The bolt you removed could be the fender attach point. I would put that back. There are no bolts for the Interstate seat. There are two hooks molded into the bottom of the seat pan, and a bracket that goes into the rear trunk mount, and the latch, that's it cooldude
kenf
2000 Interstate
Ontario Canada
« Reply #2 on: September 27, 2014, 06:39:11 AM »
Been a while since I had a stock seat on mine but my original had a strap across the middle attached on each side of the seat. As stated unlock at the front, undo the strap on both sides of the seat then lift and slide forward. There is no bolt at the back.
[IMG]http://i1253
[IMG]http://i1253
« Reply #3 on: September 27, 2014, 07:29:59 AM »
Yes strap across center. Nuts on chrome piece holding them on is 10 or12mm can't remember which.
Michvalk
Remus, Mi
« Reply #4 on: September 27, 2014, 07:55:59 AM »
Yup, I forgot about the strap. First thing I removed when I got the bike. cooldude
« Reply #5 on: September 27, 2014, 08:00:52 AM »
      NOT a good plan to run WITHOUT that strap as it holds the rear of the seat to the M/C. But as to the original post-strap removal key into front of center section between side covers and turn key. Little W D 40 on the hooks when you get seat off helps the next time. RIDE SAFE.
« Reply #6 on: September 27, 2014, 01:25:48 PM »
I totally agree that it's important that the strap be in place on the OEM seat. Most people don't get that seat locked into place mid way back. It's a PITA to get it in that shoe. The only thing holding that part of the seat if it's not held by the shoe is the strap which is held in place with 12 mm nuts.  FWIW
My rides:
« Reply #7 on: September 27, 2014, 03:15:07 PM »
Gotta call BS on this one if anyone is relying on that strap they need to learn to put the seat on properly. This is only my opinion but will stand by it.
PhredValk
Edmonton, Alberta, Canada
« Reply #8 on: September 27, 2014, 07:30:01 PM »
I took off the strap the first time I removed the seat and never put it on again. Too much of a pain to unbolt it every time you need the seat removed. If the rear bracket and front lock make the seat solid enough to lift the bike upright from a fall, it's not going anywhere. I use the strap to remove the battery now...
Fred.
VRCCDS0237
