November 26, 2025, 04:42:04 AM
Carb adjustment.
Topic: Carb adjustment. (Read 726 times)
ValkyrieRider
Covington GA
Carb adjustment.
September 28, 2014, 05:48:26 PM »
I have a 97 Valkyrie. I had it dynoed and set up for riding in Colorado a few years back. I just moved to Georgia for a new job. Since I got here the gas mpg has dropped off. I is down in the 26 mpg from around 32mpg that I got in Colorado. I am wondering if it is due to the altitude change and that it may be running lean now.
Thanks for your help.
Eddie.
Support Our Troops.
U.S. Navy 1980-1985
Former Colorado Patroit Guard State Caption.
1997 Valkyrie Tourer. Stars and Stripes.
Crackerborn
SE Wisconsin
Re: Carb adjustment.
September 28, 2014, 07:53:42 PM »
Altitude alone should not cause that big of a drop off in MPG. Check to see if you are dragging a cylinder or two...no spark, no fuel are the usual suspects. Pull the plugs to see if they all look consistent. Nothing wet or overly tan/white colored. Wet means no spark, light coloration means starved for fuel.
97 Valkyrie Tour
99 Valkyrie Interstate
September 28, 2014, 09:46:17 PM »
32 isn't very good: 26 is very bad. We need to know what has been done to the bike. Pipes, carb adjustments, K&N filter, etc. I get 37 at 70 MPH and recently freeway construction has slowed me down. My last tank was 39 MPG.
Michvalk
Remus, Mi
September 29, 2014, 01:49:48 AM »
If it's eatin' fuel, I would sooner think it's running rich. JMHO!
September 29, 2014, 03:46:06 AM »
High altitude settings require the pilots to be reset .5 turn, so just to run properly at lower altitudes try setting the pilots back to 2.25 turns [ 35 jets].
=> InZane XXV
