February 09, 2026, 02:51:25 PM *
Author Topic: Timming Belt Tensioner Rebuild  (Read 1312 times)
lee
Northeast Tennessee
« on: September 29, 2014, 06:22:52 PM »
I replaced my timming belts at 100,000 miles.  Both tensioners had a small amount of play in them.
Plus they sounded like there was no grease in them.    So I replaced them with tensioners from
another engine I had that only had 25,000 miles on them.
After reading Highbinders post about the tensioners I decided to rebuild the old ones.
The backing plate is 3/16" thick.  The hole is 14mm.  Half of the hole  has an 82deg. taper.  (see pic)
The bearing is a Gates T-42015.  It has a 10mm hole in the center.
The bolt I found is a 10mm Socket head Hardened bolt with an 82deg. taper.
I did not want to drill the hole in the bearing out to 14mm.
The bearing is flat on the back side.  So when the bolt is tightened down it centers itself in the hole.
Since they both have the same taper.
I used a lock washer and lock nut.
Does anyone see any problems with this set up?
« Last Edit: September 29, 2014, 08:26:44 PM by lee » Logged
Time is not what is taken but what remains.
C. Drewry
jimmytee
Elizabethtown,KY
« Reply #1 on: September 29, 2014, 07:13:03 PM »
 cooldude I did  basically the same thing 11 K miles ago.
http://www.valkyrieforum.com/bbs/index.php/topic,54029.0.html
Highbinder
Bastian/Tazewell,VA.
« Reply #2 on: October 01, 2014, 05:14:14 AM »
Lee, when I put that post up, I had already ordered 2 new tensioners, got the bill...80 bucks apiece... Angry.....but I did keep the old ones and intend to rebuild them, thanks to your post that will be easier and a hellva lot cheaper.. cooldude
Joe Hummer
Arnold, MO
« Reply #3 on: October 01, 2014, 08:15:52 AM »
I don't know if it was a bad tensioner or I held my mouth wrong when I installed it...but I had a brand new tensioner (Gates) start making noise on me right from the get go.  I hoped it would go away but it didn't.  Replaced it with another one and all was (is) good.  The replacement was MUCH easier after the modification.  Cheesy
1999 Valkyrie Interstate
