February 09, 2026, 02:51:16 PM *
Author Topic: no headlight  (Read 1454 times)
« on: September 30, 2014, 03:37:08 PM »
Started tourer up this morning and ran into the house to get stuff. Came out and i had no headlight. Everything works but the head light. No highbeams either. Had to get to work so nothing was checked. Volt meter showed all good. Gonna check the bulb and fuse tomorrow night. Any other suggestions?
« Reply #1 on: September 30, 2014, 03:59:45 PM »
Ya might try flipping your starter button.
That is the last thing you touched I'm assuming.
It also turns the headlight off during the starter cycle.
Worth a shot.
Keep us posted in your find.
« Reply #2 on: September 30, 2014, 04:27:35 PM »
Yup did tht. Even turned it the bike on and off a couple times. Also hit the starter button while it was running. Starter switch was cleaned in may.
« Reply #3 on: September 30, 2014, 05:36:19 PM »
Well I was gonna suggest what RJ did but since you tried that I would say try a new bulb and check fuses.
« Reply #4 on: September 30, 2014, 06:06:04 PM »
Is your headlight higher wattage than original? If so, you may have damaged the plug on the back of the lamp.
« Reply #5 on: September 30, 2014, 06:14:10 PM »
Its a sylvania silver star. 2nd bulb in 10 yrs. Changed 5 yrs and 50k ago.
Highbinder
Bastian/Tazewell,VA.
« Reply #6 on: October 01, 2014, 05:07:15 AM »
I had that happen several years ago, so I'm going to give you what I can remember... Smiley under the left side cover where the relays are, there is a connector plug that the lights run through, that was corroded and that was the problem..cleaned it up and everything worked fine... cooldude
« Reply #7 on: October 01, 2014, 06:33:44 AM »
There is no relay in the headlight circuit of the Standard or Tourer.
Fudgie, are your tail light and meters dark and your accessory terminal not working?  If so, the problem is with the IG2 circuit of your ignition switch.  If not that, I would check things in the following order:
1. Check headlight fuse.
2. Change headlight bulb.
3. Use an ohmmeter to check continuity between the green wire at the headlight socket and the negative battery terminal.
Steps 4 and 5 with the ignition on:
4. Check for power to the blue/White wire in the headlight case.  It takes power from the start button to the high/low switch.  If no power, check blue/red wire to the start button.
5. Check the blue (high) and white (low) wires for power from the high/low switch to the headlight.
« Reply #8 on: October 01, 2014, 08:33:38 AM »
OK, but is it a higher wattage? Personally I don't think that's your problem, I've had both hi & lo go out almost simultaneous, just doesn't usually happen that way. Either a blown bulb or a gummed up hi/lo switch on the left side....or both.
Daniel Meyer
The State of confusion.
« Reply #9 on: October 01, 2014, 08:37:27 AM »
Likely starter button...
http://valkyrieriders.com/shoptalk/VSGPages/starterbutton.htm
CUAgain,
Daniel Meyer
« Reply #10 on: October 01, 2014, 02:02:03 PM »
Fuse is good and working on getting the b'wing off and check the bulb. Starter switch will be next.
Everything else works, tail lights, brakes, turn sig, all my acc, and kury volt meter is green.
Headed out to the garage now.
« Reply #11 on: October 01, 2014, 02:07:46 PM »
Keep digging buddy.
You will find the problem.
 Evil Evil         tickedoff tickedoff        angel angel
« Reply #12 on: October 01, 2014, 03:41:06 PM »
Fixed
Broken solder at the switch. Soldered it up and all good.  cooldude
« Reply #13 on: October 01, 2014, 03:49:41 PM »
Good show buddy.
Now ride her like ya stole her.
Knowing you that will just be a piece  of cake and with your eyes shut.
