March 11, 2026, 11:54:04 AM
Electrical Brake Cables...
Topic: Electrical Brake Cables... (Read 1175 times)
Big Rig
Woolwich NJ
August 13, 2009, 02:59:01 PM »
I super Valked my Valk (I took the trunk off) and have jury rigged the rear brake cable, is there a clean alternative? Will a standard rear brake (electical) cable work? Are they plug and play? I check Honda Direct and have had no luck finding a part number, do they carry them? Where can i find one and how much $$$ is typical? 99 I/S....
shortleg
maryland
Re: Electrical Brake Cables...
August 13, 2009, 05:20:49 PM »
I take it you are talking about the wire harness.
What I did was just used a three conducter wire
and taped in front of the connecter for the trunk.
Just place a three pin connecter in it so you can
take off your fender if need be.
Hope I was clear.
Shortleg[Dave]
Bagger John - #3785
August 13, 2009, 06:37:09 PM »
If you want "waterproof", use a Deutsch (H-D) or Hitachi OEM-style connector. The latter can be obtained through most large electrical supply houses such as Mouser, Digikey and Newark Electronics.
Big Rig
Woolwich NJ
August 13, 2009, 08:30:08 PM »
Yes the wire harness. I was hoping that I could run a standard harness through the fender and plug and play when I remove the trunk. Does anyone know if the start connector mates with the I/S? I installed a 99 Standard oem rear brake night...anyone else do this???
