February 09, 2026, 02:52:41 PM *
Author Topic: tube set, drain  (Read 854 times)
dubsider
Flat6 baby #33034
Dublin GA
« on: October 06, 2014, 08:11:54 AM »
I noticed a crack in a piece of tubing at the nipple on the carb (drivers side back left) that goes to the underside of the tank to the 6 joint connector.. I dont want to replace all at this time - just the one that is cracked.. What size is this tubing??  http://www.ronayers.com/CARBURETOR-TUBING-C206963.aspx it is Part #5 in the diagram - small tube on the lower right of #5
« Reply #1 on: October 06, 2014, 12:24:04 PM »
Drivers side back left ? Not sure what means, but, no matter. It sounds like you're talking about the lines attached to the carburetor drains. Thats not an issue. You may be able to snip it off and just reattach it, or, not worry about it. See if there isn't a screw head in the carburetor right next to the line, that line only means anything if you drain that carb.
dubsider
Flat6 baby #33034
Dublin GA
« Reply #2 on: October 06, 2014, 12:55:53 PM »
thanks Patrick -
yea, I was trying to describe which carb, but they all have this tube exiting to the drain. I will try to snip the end off and reattach to the carb.
best- neal
rhinor61
Northern California
« Reply #3 on: October 06, 2014, 03:37:27 PM »
FYI,
Each cylinder has a corresponding carburetor.
Each OEM spark plug wire has the cylinder number on them.
Odd number cylinders on the drivers right, starting from the front to the back.. 1-3-5
Even number cylinders on the drivers left, starting from the front to the back... 2-4-6
hope this insight is helpful...
John
Northern California
1998 Valkyrie Tourer Black/jade
VRCC #28001
dubsider
Flat6 baby #33034
Dublin GA
« Reply #4 on: October 06, 2014, 07:53:13 PM »
thanks rhino -
that makes it clear.. so carb #6.
This afternoon I took her to my master mechanic, tire changer, and now drain tube changer - for the quick and easy repair.. He is a great friend and entrepreneur who has a real lift that makes it - quick and easy for fixes such as these Smiley
Momz
ABATE, AMA, & MRF rep.
« Reply #5 on: October 07, 2014, 04:45:09 PM »
Is the Drivers side the left side?
Would it be the same if you were in the UK?  Wink
ALWAYS QUESTION AUTHORITY!
