February 09, 2026, 02:51:24 PM *
Author Topic: Running like crap- 2001 Interstate  (Read 961 times)
delucaj
« on: October 07, 2014, 06:50:58 AM »
My 2001 Interstate is running like crap. Only 9000 miles on the clock.   Have not ridden much this year and have a good dose of Seafoam and fresh gas in the tank for a month now.  Starts and idles OK but will not take the gas when I turn the throttle.  Doesn't die but sputters horribly.  Pretty much chokes when starting off in first gear.  Really not rideable the way it is.
I always store it over the winter with Stabil and have never had a problem before.  I'm thinking it cant be all six carbs but it feels like it.  Could a vacuum line be the problem?
What do you guys think?
« Reply #1 on: October 07, 2014, 08:00:45 AM »
Well, it could be vacuum lines, especially if they have never been replaced. Take a look at them. Better yet, just replace them. Don't forget the caps.
It sounds as though you have a bad case of varnished low jets. Have you tried flushing the carburetors ?  Flushing means to me flushing fuel thru the carburetor float chambers by opening the little drain screws located on the bottom of the float chambers.
If you have been trying to run it with fresh fuel and Sea-Foam without success, [ try to get it rideable to run a couple tanks with full cans of fuel cleaner] , then it may be time to get your hands dirty and clean some carburetors.
« Last Edit: October 07, 2014, 11:24:10 AM by Patrick » Logged
« Reply #2 on: October 07, 2014, 08:17:03 AM »
First thing, I would say, is to drain some gas from each float bowl.
It may help.
Valkpilot
What does the data say?
Corinth, Texas
« Reply #3 on: October 07, 2014, 11:20:42 AM »
Vacuum leaks masquerade as carb issues, so making sure all vacuum lines are in good shape, making sure that the intake boots are properly seated on the carb intakes, making sure the 18 bands that secure the intake boots to the carbs and carbs to the intake tubes are properly tightened, and making sure that the o-rings under the intake tubes are in good shape, are all points to verify first.  And, they're pretty easy to bring up to snuff.
Also, a failing OEM petcock, or cracked vacuum line to the OEM petcock will cause fuel flow issues, and so also masquerade as carb issues.  Also easy to check and fix.
After you satisfy yourself that you aren't chasing a vacuum ghost, keep trying to run the bike with heavy doses of carb cleaner.  As Ricky-D suggested, I would drain the bowls first.  You may not have run it enough to use up the old gas in the bowls and start to pull the carb cleaner / gas cocktail through the carbs.  I would also alternate between cleaning agents.  Seafoam is good and acts as a stabilizer besides.  Techron is a very good cleaner, but not a stabilizer.
Finally, before you tear into the carbs, try a technique that has been successful for a couple of people around here.  Get your hands on some Yamalube carb cleaner.  Remove the tank.  Drain the carb bowls. Pour the Yamalube cleaner in the fuel line and crank the engine to draw it into the carbs.  Lather, rinse, repeat until you're sure the carbs and carb bowls are full of the Yamalube cleaner.  Let it sit over night, then repeat the process starting with draining the carb bowls.  Let it sit overnight again, then drain and remount the tank and try and fire up the bike.  This has cleared some very stubborn clogged jets in bikes that sat for a long time before finding new homes.
VRCC #19757
IBA #44686
1998 Black Standard
2007 Goldwing
Momz
ABATE, AMA, & MRF rep.
« Reply #4 on: October 07, 2014, 04:39:33 PM »
Seafoam is good for fuel system maintenance.
But a whole can of Berrymans B12 Chemtool in a full tank and a long ride under 3K RPM will do wonders for your drivability issues (assuming there are no vacuum problems).
Berrymans is available at most auto parts stores.
ALWAYS QUESTION AUTHORITY!
« Reply #5 on: October 07, 2014, 08:15:29 PM »
Carb problem or vacuum leak?
Can you get the RPM up high enough (others will confirm how high), like 2.5 - 3K and higher, and the sputtering goes away?
A vacuum problem should always be there shouldn't it, guys?
If you can get the RPM from low jets, to the high jets, which is when the higher RPM is reached, and it smooth out, then it is a low jet issue.
With only 9K miles, you have varnish issue, almost no matter how well you treated the bike, except if you drained all fuel when it was being stored.
Like already mentioned, high strength cleaner to fuel. You don't need to fill the whole tank with gas, 1/2 a tank with 1/2 a can of cleaner will do it. Go out and get it to drive a slow speed and high gear, so those low jets get used and have cleaner going through them to try to eat some of that crude away.
« Reply #6 on: October 07, 2014, 10:03:10 PM »
My 2001 Interstate is running like crap. Only 9000 miles on the clock.   Have not ridden much this year.
Sounds like the problem is that it sits a bunch.
