February 09, 2026, 02:51:28 PM
Running a little warm.
Topic: Running a little warm. (Read 975 times)
Jttingle
Done the Dragon?
East Coast, MD
October 07, 2014, 05:50:16 PM »
97 CT was down for a few months while chrome work getting done (not related). Back on the road but engine seems to be running a little warm? Fan is turning but not for long. Should I change thermometer first? Water Pump? Fan? or just do all three. Bike has about 50k on it. Running good and doesn't seem to be overheating it's just that engine is putting off more heat than I remember? Haven't been too far on it and cooler riding temps now. Any advice would be helpful.
What ever it is, it's better in the wind.
Re: Running a little warm.
October 07, 2014, 06:09:55 PM »
Really doesn't sound like you have problem. Not much quantitative info to go on.?
My rides:
Brewer
Denver, CO
October 07, 2014, 07:00:42 PM »
"doesn't seem to be overheating"
Run it and check with a thermometer
take the guess right out of the equation.
Brewer - it is a hobby
Rio Wil
October 07, 2014, 07:06:48 PM »
Is the overflow tank up to the full mark (under the left side cover)
Any coolant in the overflow tank at all?
Is the radiator full of coolant. Careful with the little set screw in the radiator cap.
longrider
Vernon, B.C. Canada
October 07, 2014, 08:44:50 PM »
Other than the thermostat nothing would really change unless the system was low before and or a leak has developed while sitting. I have noticed over the years that a small amount of tree fuzz, bugs etc do get caught up in the rad and can starve the rad a bit. I remove the rad every three years or so, lay it on an old towel and wash it from the backside. It's amazing what comes out of it. Even in 100' temps mine holds 185-190 on the highway.
Warren
October 07, 2014, 09:59:50 PM »
Don't sound like a problem from here.
Reply #6 on:
October 08, 2014, 03:39:38 AM »
our bikes don't run warm.
this engine was designed to be fully encased in body work with side mounted radiators, the GL1500 GWs never had a heating problem.
Valkyrie engines use the same thermostat and water pump as a GL and have a forward facing radiator.
Last Edit: October 09, 2014, 05:12:00 PM by CA
Reply #7 on:
October 08, 2014, 05:29:50 AM »
Peroxide sprayed into the radiator fins will dissolve bugs and loosen other debris. Wait a few minutes and hose out.
Jttingle
Done the Dragon?
East Coast, MD
Reply #8 on:
October 09, 2014, 04:08:41 PM »
Thanks for the input, will clean and check and keep an eye on it
