January 29, 2026, 10:16:52 AM
Oil Leak
Topic: Oil Leak (Read 1950 times)
Six Packer
Oil Leak
August 14, 2009, 03:55:33 AM »
Noticed some oil leak on my garage floor. Never had this happen before with owning Valks for 10 years and I was surprised to see it.
Got under the bike and checked around and saw where the oil was running down the case--not a big leak but enough. Tightened up all the bolts and wiped off the oil, started it up and got under the bike again to see if I fixed the problem. I didn't see any leakage but when I was getting up off the floor I noticed the filler cap didn't look right. Sure enough, the cap was about a 1/4 turn loose and I guess that was enough to allow the oil pressure to find its way there.
The moral of the story I guess is to check the filler cap from time to time . Hope this reminder helps someone.
Re: Oil Leak
August 14, 2009, 07:06:23 AM »
The real moral of the story is:
Valkyries dont leak oil
So, if you see oil, look for things like loose filler caps first before assuming the worst and tightening already torqued engine casing bolts......but its just a matter of point of view I suppose......
Glad you dont have a problem
junior
new hampshire
Re: Oil Leak
August 15, 2009, 04:25:57 AM »
and dont park in the same spot where a harley had just left
Re: Oil Leak
August 15, 2009, 07:10:57 AM »
Quote from: junior on August 15, 2009, 04:25:57 AM
10-04 what Jr says.
Printer Mike
Eatonton, Georgia
Re: Oil Leak
August 15, 2009, 10:47:46 AM »
Never experienced it, but from what I've heard, might get a small leak from the shifter seal....An easy fix to replace the seal.
Never give up!
