February 09, 2026, 12:56:45 PM *
Author Topic: Switched Power  (Read 969 times)
dancnman
Houston, Texas
« on: October 19, 2014, 02:58:37 PM »
I want to switch my amp using the key switch with the acc position as well as the on position of the key. I know where the 5 amp wires are that are switched on with the key, but they are not powered by the accessory position of the key. Can someone tell me where to pick up the acc wire for my amp trigger wire?
Jerry
Reality is that thing which does not change simply because I choose to ignore it.
BigBad1
1999 Interstate
Garner NC
« Reply #1 on: October 19, 2014, 11:43:12 PM »
Inside the right side cover there are two large connectors under a clear cover. These are where your radio connects. One of the connectors is blue and the other is green. Use the blue wire at one end of the blue connector. This blue wire will work when the ignition is on and in the acc position. I'm sure you already know that you can only use this wire for the trigger. Most amplifiers will need to be connected directly to the battery or a high amperage fuse box. The amplifier should have a trigger wire that will turn the unit on and off by a relay. Tap that trigger wire into the blue wire mentioned above.
« Last Edit: October 19, 2014, 11:46:32 PM by BigBad1 » Logged
dancnman
Houston, Texas
« Reply #2 on: October 21, 2014, 05:23:57 PM »
Thank you very much. That was it.
« Reply #3 on: October 21, 2014, 08:33:26 PM »
What "acc position"?  The I/S has an accessory position?
vanagon40
Greenwood, IN
« Reply #4 on: October 21, 2014, 09:08:37 PM »
Yes, the ignition switch is different from the Standard.  Many parts are interchangeable, but there is the extra accessory position on the interstate switch.
« Reply #5 on: October 23, 2014, 10:15:14 AM »
Rotate the top of the key towards the rear of the bike, opposite of the ON position.  The LCD dash will light and the radio will play.  I use it all of the time while working on or cleaning the bike....  Smiley
Hay  Cool
