February 09, 2026, 02:50:07 PM *
Author Topic: cold weather starting  (Read 1942 times)
SVK100
Saskatoon, SK
« on: October 25, 2014, 01:12:18 PM »
I just picked up a 2001 Interstate 6 weeks ago and just love the beast. Being in Western Canada it is getting fairly cool. I am having a problem staring it in the mornings (temp about 30F or -2C). It wants to flood very easily and I have not used the hand throttle or the choke. It takes a good 10 spins before it can run. Can certainly smell fuel and reacts like it is flooded. I have read some of the comments from other riders but not sure we have the same problem. Any suggestions. Thank you
eric in md
« Reply #1 on: October 25, 2014, 01:21:32 PM »
push your choke,, as it stops push it 1/4 farther.. see if that dont help..
« Reply #2 on: October 25, 2014, 02:42:14 PM »
+1  cooldude when you think the choke is open push it more it won't break but you will think it will ???
fordmano
San Jose, CA.
« Reply #3 on: October 25, 2014, 02:48:19 PM »
If you think it is over fueling then Shut the fuel off at the Petcock until it actually tries to start. Not knowing your mechanical experience it is very difficult to really explain what to do.
Maybe you need to have the carbs synched or maybe some other issue needs attention in your carb/fuel system. In the type of temps you mention mine has definitely needed a choke but always started reasonably easy if the battery was at full charge and no fuel/carb issues.
« Last Edit: October 25, 2014, 02:50:08 PM by fordmano » Logged
83GS550
93XR650L TARD!
97WR250
99ValkyrieI/S Tri-tone
01YZ125(x2)
05DRZ-125
« Reply #4 on: October 25, 2014, 02:59:12 PM »
Shut the petcock at night. Smelling fuel before it starts tells me there might be another issue. Before starting, pull all the plugs to see if you have fuel dampness on them. Issues could be petcock leaking or carb floats leaking. Put the battery on a smart charger in those cold temps. www.CTEK.com  Model 3300 is what I use.
KY,Dave (AKA Misunderstood)
Specimen #30838 DS #0233
Williamsburg, KY
« Reply #5 on: October 25, 2014, 03:27:26 PM »
He's NOT using the choke  Roll Eyes
« Reply #6 on: October 25, 2014, 03:32:57 PM »
I understood that but I think he should be. coolsmiley
Michvalk
Remus, Mi
« Reply #7 on: October 25, 2014, 06:32:49 PM »
Make sure you are closing the choke all the way, and don't touch the throttle. Should start right up and gain engine speed as it warms. Every one of these things start slightly different, but, this should work for you. If it still wants to flood, you may have one of the other problems described. cooldude
Fiat Lux
Lethbridge, Alberta
« Reply #8 on: October 25, 2014, 07:22:08 PM »
Good hear from another Valk ride in the Prairie West! I have a 2001 Standard in black with a silver stripe.
Cool weather starting is a problem for me too. Set the choke at this time of year and don't touch the throttle no matter how slowly it seems to be running.
Fiat Lux
Lethbridge, Alberta
« Reply #9 on: October 25, 2014, 08:47:29 PM »
But he needs to.
Williamsburg, KY
« Reply #10 on: October 26, 2014, 02:40:48 AM »
But he needs to.
He says it seems to be flooding easily. He also smells fuel heavily and acts like it is flooded. Not sure how the choke would help that. Seems there is another issue here other then a lesson in how to use the choke which I know is a common mistake of some.  cooldude
« Reply #11 on: October 26, 2014, 10:08:27 AM »
SVK100, keep in mind, these carbs don't have an accelerator pump so blipping the throttle before hitting the starter only exercises the wrist....nothing more. As for the fuel smell, I agree with others....you may have another problem lurking, such as a petcock starting to go bad. If the engine starts to turn over with the starter and suddenly comes to an unexplained stop, do NOT hit the starter again. Pull the plugs to see if one cyl. is full of gas. If you keep hitting the starter, you'll tear up starter gears inside and will be looking at a major repair. Do as suggested, turn off the petcock the night before and use the choke when starting the next day. If/when it starts, turn on the petcock. If that helps, you do have a petcock problem. As for the choke lever, while it moves easily you're just taking up slack. At that point press it down past where it moves easy...now you're engaging the choke. Keep us posted on what you find.  cooldude
« Reply #12 on: October 26, 2014, 10:38:15 AM »
First thing I would do is start the bike, and go for a ride.
When you're somewhere you know you can go for miles without stopping (back country road), turn off your petcock.
The engine should start starving for fuel about a mile or so (some report sooner, others longer). Then turn it back on.
If it doesn't starve for fuel, then you have a petcock problem.
Kunkies
Charlotte, NC
« Reply #13 on: October 26, 2014, 11:50:09 AM »
use the choke.
How thick is your oil?  30 degree weather and 20w-something viscosity is NOT conducive to an easy cold start nor it it good for your engine.
Radman
Hamilton, ON. Canada
« Reply #14 on: October 29, 2014, 12:32:40 PM »
But he needs to.
+1
Coming from Canada as well....I've got the same issue with starting in the cold weather.  Push choke all the way...push more....don't touch the throttle and she should start right up.
Do try the empty road and turn fuel petcock off test as well.  Should be in 2-4kms of fuel in your line before you start to starve the engine of fuel.
signart
Crossville, Tennessee
« Reply #15 on: October 29, 2014, 12:39:31 PM »
Don't understand recommending activating the enricher (choke) for an engine that is flooded as the op implies. ???
« Reply #16 on: October 29, 2014, 03:44:39 PM »
Maybe he only starts smelling gas after the seventh or eighth try?
It would be a weird Valkyrie that would start easily without the choke at 30 degrees...
« Reply #17 on: October 29, 2014, 05:40:51 PM »
The original poster has not come back, so lets wait to hear back before conjecturing more ifs.
« Reply #18 on: October 29, 2014, 07:08:51 PM »
Profile says he hasn't visited since post.  Undecided
Williamsburg, KY
« Reply #19 on: October 30, 2014, 04:12:03 AM »
Hate when that happens or they never let you know outcome so we have references for the future  Sad
Icelander
Snohomish, WA
« Reply #20 on: October 30, 2014, 09:51:54 PM »
Well, I'm grateful for this post as I thought maybe my choke was malfunctioning. Turns out that the lock nut at the handlebars was loose but it also caused me to look seriously at the choke. Felt like an idiot when I noticed that the choke could move further.
Got her out this morning in 40 degree weather here in Seattle and she started *so* much easier. Smiley
Thanks guys!
Kendall
1998 Valkyrie Tourer.
VRCC Member #36337
SVK100
Saskatoon, SK
« Reply #21 on: October 31, 2014, 04:05:12 PM »
Hello, very sorry for the delay in responding. Thank you for insisting on really insisting on hammering down on the choke. It definitely turns over and idles at a steady 2000 rpm. Regarding the fuel smell, I am trying to see if it is a vent problem. I had quite a bit of play in the throttle (because of the throttle), I tighten this up, will see if this had anything to do with it. With below 32F weather and no warm garage to work in, this makes it more of a task (winter is approaching). Possibly a spring job. I want to thank you all for your help and I will keep you all posted on the progress.
« Reply #22 on: October 31, 2014, 04:43:55 PM »
Thanks guys!
Kendall
Don't feel bad. I went a year before I realized I could really use the enricher.
flcjr
Manhattan,Montana
« Reply #23 on: November 03, 2014, 03:57:07 PM »
Mine finally broke this fall  Sad
sawdustar
Conway, AR
« Reply #24 on: November 05, 2014, 01:21:19 PM »
hey, if I apply choke, it won't stay but does slowly go back towards the normal run position. Is there a way I can apply more tension somewhere so when I apply choke it will stay?
Thank You,
Dennis
« Reply #25 on: November 05, 2014, 01:38:07 PM »
I took my clutch lever off and cleaned and lubed the little brass frob and the
pushrod and stuff.
When I put it all back together, my choke lever started returning on its own.
Anywho, if you look down to your right, at the carb tops, you can see what is moving
when you push the choke lever. If I hold that down for a few seconds after I engage the choke, it
"pretty much" stays. It is getting better, hasn't been long...
Have you lubed anything near the clutch lever/choke lever recently?
sawdustar
Conway, AR
« Reply #26 on: November 05, 2014, 02:58:18 PM »
pushrod and stuff.
Mike,
No I haven't. I've wanted to, but I have not had the time to take it all apart and clean/lube things up. It's been this way since I was given the bike just over a year ago.
Thank You,
Dennis
