February 12, 2026, 01:17:17 PM *
Author Topic: alternator front bearing replacement  (Read 2121 times)
jmann
Mesa,Az.
« on: October 26, 2014, 12:14:49 PM »
I just replaced my alternator brushes and rear bearing. The brushes due to miles and the bearing because of a cold start up "squeal" that I felt was a bearing noise. It goes away after a few minutes of warming up. Only happens in cold temps too. I was in cold temps this weekend for the first time since rebuilding and the noise is still there. The rear bearing had a lot of slop so I thought after I replaced it it was going to be cured but now I am thinking the front bearing might need addressed. My shop manual says to replace the whole front rotor assy. but that is almost the cost of an alternator. Anyone ever replaced the front bearing and if so got a part number. Thanks for any help you might be able to provide.
quexpress
Montreal, Québec, Canada
« Reply #1 on: October 27, 2014, 10:07:03 AM »
Front seal: CR8845
Front bearing: 6022DU
Rear bearing: 6000DU
I have not done these repairs but have "borrowed" this information from Goldwingfacts.com  Cool
I still have a full deck.
I just shuffle slower ...
jmann
Mesa,Az.
« Reply #2 on: October 27, 2014, 10:53:41 AM »
Front seal: CR8845
Thank you very much for the info.  cooldude
Highbinder
Bastian/Tazewell,VA.
« Reply #3 on: October 27, 2014, 04:00:46 PM »
You might want to check your water pump bearing, I had a squeal sound that was low pitched and sounded like it was coming from the alternator, after putting a long handled screw driver on the alternator and placing my ear on the end to the screw driver, I was able to pin point the sound and it was coming from the water pump...you might want to check it out before pulling the alternator again...usually that front bearing doesn't go out...good luck.. cooldude
jmann
Mesa,Az.
« Reply #4 on: October 28, 2014, 06:31:31 AM »
Thanks highbinder. I will give that a check before I pull it out again. It is more of a high pitch squeal and since I removed and replaced the rear bearing the sound changed just a little. I was thinking I had maybe disturbed it a little when cleaning. When I inspected the rear bearing I thought for sure that would have been it but it wasn't. It really is pronounced when it gets below about 40 degrees and it hasn't been quite that cold yet. I will break out the stethoscope and keep it handy for the next time it happens.
