April 30, 2026, 02:52:36 AM *
Author Topic: Florida Tech question  (Read 2646 times)
Tundra
2014 Valkyrie 1800
Seminole, Florida
« on: November 04, 2014, 02:56:39 AM »
When I apply my brakes, just before I come to a complete stop (from any speed) I hear/feel a click. Just one click, every time? Any thoughts? Steering head bearing?
« Reply #1 on: November 04, 2014, 04:49:23 AM »
Of course the front brake switch at the lever clicks.  And our rotors are floating.
IamGCW
727 hood
« Reply #2 on: November 04, 2014, 05:51:39 AM »
Floating calipers.
We could attach my go-pro to the bike and try to catch the sound and movement if you want to localize it.
Gil
Gil
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #3 on: November 04, 2014, 06:42:32 AM »
Its not the calipers/brakes. Im very familiar with our floating calipers. Its when you've come to a complete stop and the weight of the bike transitions back off of the front forks. I feel it more than hear it. Feels like play in the front end.
Flrider
Jack
Kissimmee FL
« Reply #4 on: November 04, 2014, 08:32:09 AM »
Maybe the steering stem nut. ???
IamGCW
727 hood
« Reply #5 on: November 04, 2014, 10:22:53 AM »
+1 and maybe check the fender mounts.
Gil
Gil
Valkahuna
DeLand, Florida
« Reply #6 on: November 04, 2014, 11:21:53 AM »
Could it be your forks topping out all the way up? I've had something like that with low fork oil, though Not on my Valk.
2014 Indian Chieftain
2001 Valkyrie I/S
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #7 on: December 14, 2014, 05:42:25 AM »
This is much worse and is now a pronounced clunk every time the fork is under compression. Not floating brake calipers. Floating calipers with loose pads will make noise when NOT braking. If I can finish my honeydews today, up on jack stands and check for play. Any other thoughts? Low fork oil? I do have progressive springs although they are far from new, been installed about 9 years.
 Whatever this turns out to be, it's Billy's fault. I beat the crap out of my bike trying to keep up with him. Evil
« Last Edit: December 14, 2014, 05:53:00 AM by Tundra » Logged
IamGCW
727 hood
« Reply #8 on: December 14, 2014, 10:31:31 AM »
Maybe try re-centering the forks on the axle.  Where you release the pinch bolts and torque the axle then bounce it a few times  and re-tighten the pinch bolts.
Also do a close inspection of the parts for nicked or shiny spots where the parts are in contact when it makes the clunk.
Hate to think the springs inside are the cause.  Can you reproduce it sitting still?
If you want help I can drop by and give you a fresh pair of eyes and ears. (after today)
Gil
Gil
Tundra
2014 Valkyrie 1800
Seminole, Florida
« Reply #9 on: December 16, 2014, 04:34:19 PM »
 Thanks for the input...
Steering stem nut is good, fender mounts good, all shiny bolt on crap is good n tight. I put it up on jack stands and checked the forks for play, all looks good. Maybe some more experienced Valkohaulics can take a listen/feel Saturday?
Much appreciate your offer Gil, Thank you.
  It's still Billy's fault
larue
Clermont,FL
« Reply #10 on: December 16, 2014, 08:14:47 PM »
This is from the main tech board, and someone did this and problem was fixed,  hope it helps.
quote"
 There are little metal springs that the front of the pads ride on that keep tension of the pads.  IF these springs are flattened out by wear over time the clunking may be a bit more pronounced.  Try removing the pads and see if those springs are in right and actually exerting force on the pads.
quote:
Mine clunked when I put new pads on. Took them apart and the metal springs were flat. Bent them back in shape and reinstalled. Problem fixed.
« Last Edit: December 16, 2014, 08:17:01 PM by larue » Logged
IamGCW
727 hood
« Reply #11 on: December 17, 2014, 04:40:06 AM »
Maybe we need to get Billy specific bells for our bikes.  Like the Gremlin bells, but tuned for Billy.   crazy2
Gil
Gil
Bronxboy
Tampa Bay FL
« Reply #12 on: December 17, 2014, 07:20:16 AM »
Have U checked your frontal lobe  Roll Eyes May need a few shims  2funny
Grumpy
Tampa, Fl
« Reply #13 on: December 17, 2014, 09:25:57 AM »
Bottom line, the wibblin pin must be loose in the wobbling hole.
« Reply #14 on: December 17, 2014, 09:28:30 AM »
I hate when that happens.   Grin
Grumpy
Tampa, Fl
« Reply #15 on: December 17, 2014, 10:00:35 AM »
Billy's fault  Cheesy
_Sheffjs_
Jerry & Sherry Sheffer
Sarasota FL
« Reply #16 on: December 17, 2014, 10:29:04 AM »
If it was tuned to Billy it would sound like a fart.
billyboy
st petersburg fl
« Reply #17 on: December 17, 2014, 10:36:04 AM »
Man you guys just aint right.   crazy2  Just try to keep up with Jaymi.   Cheesy
« Last Edit: December 17, 2014, 10:38:17 AM by billyboy » Logged
Pappy!
Central Florida - Eustis
« Reply #18 on: December 17, 2014, 02:34:24 PM »
.......an OLD fart!
Sorry, Billy, I tried to resist that one but it was just tooooooo easy.
