November 19, 2025, 08:43:26 PM *
Author Topic: oss in the dark  (Read 1910 times)
« on: August 15, 2009, 07:02:49 PM »
started bike   no headlites  fog lites work
rode to hotel only almost got t boned a few times
called dalai  he thinks the fuse blocks are marked on the right cover can anyone confirm what the size fuse is and what fuse I CAN do without if i DONT have a spare and still get from baltimore to ny
bonnie will be in the caravan with everyonebut my middle child leaving at 9  i am leaving at 7  to beat the heat
thanks dalai for answering the phone and everyone in advance
If anyone lives on the way home my cell is 914 522 0083
Karen
Boston MA
« Reply #1 on: August 15, 2009, 07:06:03 PM »
Oss, there should be spare fuses in the fuse block...
« Reply #2 on: August 15, 2009, 08:03:03 PM »
Pull them and see what one is blown. Like Karen said there should be spares. If not head to a gas station, they should have fuses. If no luck ride it with the fogs on during the day. Alot of bikes around here use no headlight. At least you'll get home.
Scott from FL, now in Maine
Augusta, Maine
« Reply #3 on: August 15, 2009, 08:50:47 PM »
Headlight runs thru starter switch, maybe time for some switch maintenance? Cool
AussieValk
Gold Coast, Australia
« Reply #4 on: August 16, 2009, 02:32:09 AM »
That happened to me and it was the contacts in the starter switch. Only five minute fix.
« Reply #5 on: August 16, 2009, 09:46:59 AM »
made it home
boy is it hot out Shocked
The 15 amp fuse was toast so I switched the audio one into the spot and used a spare 10 in that  I didnt have a15 spare
Since I was only using the helmets speakers I was sure I would be ok since the draw would be low
Found a 15 amp at the gas station on 95 in maryland for free so I am good to go to work tomorrow
Thank you Dalai and everyone who offered assistance cooldude
« Reply #6 on: August 16, 2009, 09:56:23 AM »
I would strongly suggest you find the reason for the blown fuse. They normally do not blow for no reason.
Save you a future dilemma when the outcome could be more dangerous situation.
