November 26, 2025, 04:56:13 AM *
Author Topic: tail light assembly  (Read 1084 times)
Mike in AR
Redfield, Arkansas 72132
« on: November 07, 2014, 11:24:42 AM »
Is there any difference in the tail light assemblies of a '97 standard, and a '01 interstate? Are they interchangable?
Mike in Ar
Do not dwell in the past, do not dream of the future, concentrate the mind on the present moment.
« Reply #1 on: November 07, 2014, 11:28:19 AM »
A Standard has a tail light on the fender; an Interstate has tail lights on the trunk.
Mike in AR
« Reply #2 on: November 07, 2014, 11:41:36 AM »
My bad. I worded it wrong. I meant to say turn signal assembly. Sorry about that.
indybobm
Franklin, Indiana VRCC # 5258
« Reply #3 on: November 07, 2014, 11:47:51 AM »
I believe there is a difference in the way the lens is held on. 97 uses 2 screws, 01 uses 1 screw. Should wire up the same.
So many roads, so little time
VRCC # 5258
Mike in AR
« Reply #4 on: November 07, 2014, 12:42:23 PM »
Thanks, that 's what I was hoping for. Doesn't really matter to me about how the lens screws on, just as long as they wire up the same. Thanks again.
« Reply #5 on: November 07, 2014, 03:24:18 PM »
Yes should be wired the same. All other Honda's are.
« Reply #6 on: November 07, 2014, 05:13:29 PM »
In the back of the Clymer manual for our Valks, they have color coded wiring diagrams for standards as well as interstates.
It's the best wiring diagram I've come across.
http://www.ebay.com/itm/1997-2003-Honda-GL-1500-Valkyrie-CLYMER-REPAIR-MANUAL-/371182638396?pt=Motorcycles_Parts_Accessories&fits=Model%3AValkyrie+1500&hash=item566c35953c&vxp=mtr
« Reply #7 on: November 07, 2014, 05:47:43 PM »
Maybe clarify. The lights might use the same colored wires and are interchangeable. But the wiring harness is different between the IS and the other models.
« Reply #8 on: November 07, 2014, 05:59:21 PM »
In short this is what I was saying. Same colored wires.
RonW
Newport Beach
« Reply #9 on: November 07, 2014, 06:01:15 PM »
Still, you 'might' prefer the older turn signals (2 screws on the front of lens). The older versions include a parabolic reflector in the light shell. Either old or new, both turn signals screw in the same assembly bracket, they're interchangeable. Pics below from BigBF. More here.
2000 Valkyrie Tourer
RonW
Newport Beach
« Reply #10 on: November 07, 2014, 06:38:59 PM »
  • But the wiring harness is different between the IS and the other models.
I doubt the differences with the wiring harnesses would effect the rear turn signals' plug in. That is, the rear signals assembly is a generic/identical item designed to hook up to either a I/S or a Standard's harness.
« Last Edit: November 07, 2014, 06:42:38 PM by RONW » Logged
Mike in AR
« Reply #11 on: November 07, 2014, 09:56:48 PM »
BF, I have a Clymer's manual, although I must admit that I hadn't seen it in a while. My wife had put it in the most unlikely place for me to look(in the book shelf. Who puts books in a book shelf?)
RONW, thank you for pointing out to me about the parabolic reflector. I did not realize the newer signals didnot have them. also, thank you for the link to BIGBF's signal conversion. I installed the Electrical Connections kit several years ago. The whole reason for changing my turn signal assembly was because I had the same problem taking mine apart that he had with the nut having to be pried out. Now I know how to fix that.
   I love this board!! Someone always has an answer to whatever problem might occur. Thank you all
Mike in Ar
