November 26, 2025, 05:10:40 AM *
Author Topic: QUESTION ON OEM PART ORDERING - microfiche  (Read 635 times)
Panama
Tarpon Springs, FL
« on: November 11, 2014, 07:35:03 AM »
I'm sure someone will think this is a bit of a "silly" question, but I've never ordered "bundled" OEM parts. I'm curious if anyone knows, when looking at a microfiche, to determine parts needed in a cluster/bundle. Meaning, if you're looking for all parts "bundled" together, does everything in a highlighted box become inclusive, or does it only actually mean the "MAIN" part/housing?
Example : I'm looking to order a new front brake master cyl assembly, and on the OEM fiche at Partzilla http://www.partzilla.com/parts/search/Honda/Motorcycle/2000/GL1500CT+A/FR.+BRAKE+MASTER+CYL./parts.html I see the master cyl sub assembly (and all internal parts) contained within a "box outline", as line item "10".
What I'm not clear on - since Partzilla has not returned any of my queries - is if I order part #10, is that ONLY the sub assembly/reservoir, or is that EVERYTHING contained within the boxed outline?
Does anyone on here know, or have any experience ordering full part assemblies?
There's a fine line between being a badass and jackass... and if you try too hard to be one, you sometimes wind up being the other.
« Reply #1 on: November 11, 2014, 07:43:32 AM »
Part #10 includes everything inside the outline, including sub box #17.
Panama
Tarpon Springs, FL
« Reply #2 on: November 11, 2014, 12:04:14 PM »
Excellent! Thanks Sandy!
