November 26, 2025, 05:09:52 AM *
Author Topic: After Market Fuel Gauge  (Read 913 times)
chtwhite
« on: November 11, 2014, 03:26:07 PM »
I purchased a IS fuel tank with stock sender for my 2001 Standard; 3 ohms full and 94 ohms empty.  It reads this way with an ohm meter.  So I purchased a Classic Instruments Vintage Series Gauges VT12SLC  2" fuel gauge with settings of 0 ohms full and 90 ohms empty from Summit Racing.  I put the sender on the gauge and the ground from the sender on the ground on the gauge and power from the battery to the power and there is a full tank of gas.  It reads exactly backwards.  It goes straight to "E".  After checking EVERYTHING multiple times and making sure everything is set up correctly, I concluded it must be wired backwards and I returned it and they send me another one.  Same thing.  Goes straight to "E" when full.  I syphoned out half the fuel it goes straight down to half a tank.  So the gauge works.  I've switched wires on the ground and sender and that doesn't work at all.  I've used different grounds - that doesn't make it work either.  I've checked the tanks resistants multiple times and it changes and it reads within the ranges for full and empty.  What am I doing wrong?  Could the Vintage Brand meter simply be wired incorrectly?  I really do not know what else to try.  Any other ideas would be appreciated and considered.  Thanks for your time.
« Reply #1 on: November 11, 2014, 03:47:43 PM »
Previous posts have stated that Hondas sender is backwards from the industry standard. Motosens makes a gauge that is correctly wired for the Honda sender.
BonS
Blue Springs, MO
« Reply #2 on: November 11, 2014, 04:10:30 PM »
Here's a link to a thread on modifying the standard I/S fuel gauge sender to work with standard 90 ohm gauges:
http://www.valkyrieforum.com/bbs/index.php/topic,35073.0.html
« Reply #3 on: November 11, 2014, 04:18:54 PM »
Just mount the gauge upside down Cheesy 2funny 2funny 2funny 2funny
Pepmyster
Go Bonzo, Go!!!!
Mascouche, Quebec, Canada
« Reply #4 on: November 12, 2014, 06:34:38 PM »
 cooldude cooldude cooldude cooldude cooldude cooldude
Now this is getting interesting........
« Reply #5 on: November 12, 2014, 07:13:07 PM »
its all in your head....
E = Enough
F = Fricken Empty
Solved
