February 09, 2026, 04:59:24 PM *
Author Topic: Nuetral Light / Switch  (Read 926 times)
dug
« on: November 22, 2014, 02:42:11 AM »
Hi Chaps
I am having trouble getting the neutral light to come on, the gearbox does go into neutral but getting the light to come is a bit hit & miss ! gently tapping  the lever will get it to light , its a pain as of course until the light comes on every time the side stand is down it thinks its in gear and cuts out ,my gut feeling is the switch, I am hoping not a gearbox fault ,anyone had this?
« Reply #1 on: November 22, 2014, 03:38:56 AM »
When you are rolling up to a stop, put the transmission in neutral before ya stop.
Sometimes my transmission it is hard to find neutral.
I'd say, RIDE THE FAT GHURL.
How many miles/km are on it?
dug
« Reply #2 on: November 22, 2014, 03:52:48 AM »
30000 Miles!
« Reply #3 on: November 22, 2014, 04:03:53 AM »
30000 Miles!
This might not be a good prediction, but with that few of miles, the transmission could still be a little tight.
I would try my suggestion and see if that helps.
Keep us posted Bro.
« Reply #4 on: November 22, 2014, 06:49:45 AM »
ONLY 98000+ miles on mine and I've had her a few years and at times neutral is STILL a bitch to hit. Even using R Js suggestion. Just the nature of this particular beast. For that tiny wee bit of a glitch-ride er like ya stole er and ENJOY yerself!!  cooldude RIDE SAFE.
« Reply #5 on: November 22, 2014, 07:44:49 AM »
Your side stand issue is probably the switch. See if the wires are plugged in and if you have an ohm meter, you can test the switch.
deadwood
Albuquerque New Mexico
« Reply #6 on: November 22, 2014, 01:34:17 PM »
2001 I/S 89000 miles. I've had the same issue since I bought the bike in 2003 with 2500 miles on it.
Just ride.
Hi Chaps
Skydive New Mexico Motorcycle Club, Touring Division.
« Reply #7 on: November 22, 2014, 06:23:08 PM »
I've had this issue for years. One of these years I'll look into it, but in the mean time, the most reliable way to illuminate the light is to get it in neutral, then gently push down on the shifter.
« Reply #8 on: November 22, 2014, 07:07:07 PM »
I'm not sure mileage has anything to do with it. I have an I/S with 97,000 that lights up the neutral light easily. I have a standard with 55,000 that is pain in the butt to get the light on. Getting neutral is no problem on either but getting the the light is.
« Reply #9 on: November 23, 2014, 10:28:36 AM »
The switch for the light is inside the engine.
The detent for neutral is likewise inside the engine.
Adapting to the peculiarities of your Valkyrie
is the better option.
