February 09, 2026, 04:57:12 PM *
Author Topic: 1997 Valkyrie  (Read 892 times)
ebrenner1
« on: November 22, 2014, 02:42:51 PM »
Having a problem with cylinders 3 & 5, there is spark and compession but with the engine running and remove wires from 3 & 5 it does not affect the engine.
ebrenner1
« Reply #1 on: November 22, 2014, 03:35:14 PM »
#3 is on the coil with #4, 4 is ok and # 5 is on the coil with #6, #6 is ok and the plugs on 3 & 5  are clean.
« Reply #2 on: November 22, 2014, 04:03:33 PM »
maybe 3 & 5 carbs plugged up.  Check pressure and temp on exhaust, also start with a cold engine and see if the headers on the left side heat up the same or not.
Attic Rat
VRCC # 1962
Tulsa, OK
« Reply #3 on: November 22, 2014, 07:28:36 PM »
I would be thinking that the slow jets are stopped up not allowing fuel to those cylinders. Maybe time to pull the carbs and do a major O/H
« Last Edit: November 22, 2014, 07:30:33 PM by Attic Rat » Logged
« Reply #4 on: November 23, 2014, 10:24:17 AM »
There are a number of things to do before removing the carburetors.
First off, do a thorough gasoline additive treatment regimen.
