September 06, 2025, 12:34:11 AM *
Pages: 1 [2]   Go Down
Author Topic: Digital Carb Sync  (Read 16405 times)
dpcarson
Lillington, NC
« Reply #40 on: March 20, 2015, 06:31:08 PM »
I am good with this Tom.  It works.  Chasing perfection is a useless task chasing a moving target.  I will take these numbers any day.  Now waiting for my D- screw socket to show up so I can get those little buggers adjusted properly.  It still sounds like I am just a little lean
dreamaker
Harrison Township, Michigan
« Reply #41 on: March 22, 2015, 08:01:55 AM »
As I was waiting for the ground to freeze, so I can bring the bike from the back garage to the front garage. Something occurred to me! If I have all six hoses connected to the vac. ports, how will I keep gas flowing from the gas tank?  If I use a tee, will it effect the accuracy of the sync?  Maybe not at all! Have to wait and see.
dpcarson
Lillington, NC
« Reply #42 on: March 22, 2015, 08:10:55 AM »
I did it both with and without the tee.  the difference was very very small.  I am a first timer, but my thought was, it is going to be running with the vacuum line attached to the petcock, so shouldn't I sync it with the vacuum line attached?
« Reply #43 on: March 22, 2015, 08:12:54 AM »
You start the bike and use a surgical hose clamp to clamp the hose and then remove it from the back of #6.  It should hold the vacuum.
BonS
Blue Springs, MO
« Reply #44 on: March 22, 2015, 08:28:04 AM »
Hook is right. I pull the tube off of #6, suck on it, and clamp it. Hemostats are perfect. All I had was a small vice-grip and it worked fine.
BonS
Blue Springs, MO
« Reply #45 on: March 22, 2015, 08:35:05 AM »
If you're interested in a fully assembled Digi Sync please check the Classifieds.
http://www.valkyrieforum.com/bbs/index.php/topic,76607.0.html
gordorad
Washington, MO
« Reply #46 on: March 22, 2015, 08:45:21 AM »
Support the Arts!!    www.gordonradfordphotography.com
dreamaker
« Reply #47 on: March 22, 2015, 09:02:49 AM »
Some times my head is up my a$$, I have a Mighty Vac, so what is my problem. Some times I just don't think.  Thank You all for your help.
tz89
« Reply #48 on: April 11, 2015, 02:34:33 PM »
Here's a picture of my new black label boards. A little more expensive for me, but that's ok. They are lead-free, so they can be exported anywhere. Some minor improvements on the graphics. But most important - fast and reliable supply.
Pappy!
Central Florida - Eustis
« Reply #49 on: April 11, 2015, 03:26:13 PM »
TZ - Pretty amazing job you have done on this! Thanks so much for your efforts and for offering it to the community!
tz89
« Reply #50 on: April 13, 2015, 09:46:04 PM »
You are welcome. It's still fun.
tz89
« Reply #51 on: May 16, 2015, 10:42:52 AM »
Verical is selling the sensors for $10! That really helps keep the cost down.
https://www.verical.com/pd/freescale-pressure-sensor-MPXV6115VC6U-253910
gsxr1300x
« Reply #52 on: March 19, 2017, 07:56:05 PM »
tz, i sent you a PM. Interested in building one of your digital carb sync tools.
« Reply #53 on: March 19, 2017, 08:25:49 PM »
Or you could buy one. DigiSync was developed from this idea.
tz89
« Reply #54 on: March 20, 2017, 10:56:04 AM »
Got it. I do have some boards left. Otherwise, all the info and parts list, including the layouts for do-it-yourself board makers, is free on Github. Just search for digital carb sync.
Pages: 1 [2]   Go Up
