HotRod
Henderson, NV
« on: August 17, 2009, 10:37:35 AM » |
I called about 8 places this morning, got a good price on one at a battery shop for $48.95 6 month warranty, then I found one for $89.99 with a life time warranty, then there were the stealer's at $99.99, think I'll go with the $48.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #1 on: August 17, 2009, 11:21:23 AM » |
So, how does one define "lifetime" for a battery for warranty purposes? Would they say the life expectancy of the battery is 'X' number of years, and once past that time period the warranty no longer applies? Or, do they mean for as long as you own the battery? Heck, the way I hold onto things, that could mean >20 years!
Kingbee
VRCC# 576
Northern Illinois
« Reply #2 on: August 17, 2009, 01:29:47 PM » |
The 6 month warranty indicates the confidence they have in the battery - is that really what you want in your bike when you're far, far away from home?
HotRod
Henderson, NV
« Reply #3 on: August 17, 2009, 01:39:43 PM » |
So, how does one define "lifetime" for a battery for warranty purposes? Would they say the life expectancy of the battery is 'X' number of years, and once past that time period the warranty no longer applies? Or, do they mean for as long as you own the battery? Heck, the way I hold onto things, that could mean >20 years!  They said for the warranty to be good it's same bike same owner.
HotRod
Henderson, NV
« Reply #4 on: August 17, 2009, 01:41:21 PM » |
No it's not, your probably right, the $89 one with same bike same owner lifetime warr is probably better.
doubletee
VRCC # 22269
Fort Wayne, IN
« Reply #5 on: August 17, 2009, 01:47:21 PM » |
So, how does one define "lifetime" for a battery for warranty purposes? Would they say the life expectancy of the battery is 'X' number of years, and once past that time period the warranty no longer applies? Or, do they mean for as long as you own the battery? Heck, the way I hold onto things, that could mean >20 years!  They said for the warranty to be good it's same bike same owner. That's fair and probably the one I'd choose.
« Reply #6 on: August 17, 2009, 03:05:58 PM » |
Hotrod I would check out what the battery is for 49 before Id buy it, Honda Direct has a battery for 89. I think I bought mine for 50 to 60 and I get them wholesale so I would really wonder what the story is. Unless you have a friend in the business then that sounds a bit cheap. Not to say you couldn't have latched on to a good deal just check it out.
Kingbee
VRCC# 576
Northern Illinois
« Reply #7 on: August 17, 2009, 03:23:50 PM » |
Hotrod, where did you find the one with the lifetime warranty?
HotRod
Henderson, NV
« Reply #8 on: August 17, 2009, 04:34:35 PM » |
It's called cycle gear and they are nation wide but none in your neck of the wood according to the sales guy,I asked for ya. But he said it is lifetime and no prorate if it is indeed bad the give you a new one .
HotRod
Henderson, NV
« Reply #9 on: August 17, 2009, 04:42:35 PM » |
Shoot Wally World was $75 with only 6 month warr.
Kingbee
VRCC# 576
Northern Illinois
« Reply #10 on: August 17, 2009, 08:54:16 PM » |
Thanks, HotRod
Spirited-6
« Reply #11 on: August 18, 2009, 08:15:40 AM » |
Spirited-6
« Reply #12 on: August 18, 2009, 08:53:33 AM » |
I think batteries are a lot like tires.
Look at the weight. There are differences in weight of the same batteries (and tires) of the identical size.
To me, it means less weight equals less life. If you buy a battery that's supposed to be the same as some other identical battery, but it is 20% less weight: well if you're flying an airplane that might be a consideration but how can the difference be accounted for. Less material inside the battery. Thinner plates = less life.
Same goes for tires. Lighter tires of the same size means less rubber. Less rubber = less life.
John U.
« Reply #13 on: August 18, 2009, 03:24:39 PM » |
That sounds awfully cheap. I believe what's going on is Chinese manufacturers marketing their own brands, after contract mfg for a well known brand. Are they made to the same specs? Are the rejects actually rejected? Are there industry standards which are enforced? China these days is the wild west of manufacturing, anything goes. You may get lucky, or not.
